B1 builders thread
B1 builders thread
Old 24th December 2012, 03:43 PM   #621
6L6 is offline 6L6  United States
6L6's Avatar
B1 builders thread
The lighter note is functionally a potentiometer, correct? (I'm not really familiar...) If so, then put it in place of the cheap plastic-track chinese pot in the B1.
Has anybody done it already? I bet it has...
Old 24th December 2012, 03:56 PM   #622
voxxonline is offline voxxonline  United Kingdom
voxxonline's Avatar
B1 builders thread
Definitely will search for it.
Thank you 6L6. It was a great help.
How to find time to finish my projects ?
Old 31st December 2012, 07:55 PM   #623
sphinxvc is offline sphinxvc  United States
Hi all, would this be an appropriate "first build" for a novice DIYer? I don't have any background in electronics so it will be a complete learning experience. Haven't come across many first projects that I could call both useful & easy to build. This will fill a hole in my system and help me on my way to more complex projects (I hope?)
Thoughts?
If it's good, can anyone point me in the right direction as far what you recommend I read prior to beginning? Does PassDIY supply a BOM with the board when you buy at their site?
Thanks guys.
Old 31st December 2012, 09:30 PM   #624
Marra is offline Marra  United Kingdom
B1 builders thread
This is the original article.An easy build especially if you power it with batteries.
FIRST WATT B1
And pcb's from here.
DIY Order Form
Happy New Year.
Old 1st January 2013, 07:22 AM   #625
voxxonline's Avatar
B1 builders thread
BTW I am looking for transformer- 18 v transformer is recommended. Marra, which model would suit better- as there more different numbers, like VA etc ?
And in UK what is a better place to shop online- rs, mouser , farnell ? In some of them I can buy in bulk only and delivery charges quite high
Old 1st January 2013, 07:41 AM   #626
B1 builders thread
A transformer with 12V secondaries would be best as you would end up with about 18V dc [12x1.4].I used 50va but only because I already had one.15-30va I think would be more than adequate.Someone with more nouse than I will no doubt chip in.
Nelson recommends a wallwart supply so if you have a laptop charger that outputs 18v dc that would be the simplest answer.
I usually use Farnell but sometimes you have to buy 50 of something especially resistors or if I want something "audio grade" HiFi collective.
Happy New Year.
Old 1st January 2013, 11:47 AM   #627
voxxonline's Avatar
B1 builders thread
Happy new year.
now I m looking at my salas psu (Was planning to hook it to b1) and thinking, to put it aside until I get more skills in diy or do it now ) manual is a bit complicated...
Old 1st January 2013, 01:05 PM   #628
WithTarragon is offline WithTarragon  United States
This one is easy. go to the the local thrift shop and find an old HP laser printer. The power supply (wall wart) are usually the correct voltage (they will be marked on the PS case). Do not worry about the VA since the B1 draws very little current. I got mine for $5 and there are a ton of these avaliable.
Old 1st January 2013, 01:16 PM   #629
6L6's Avatar
B1 builders thread
Yes, it's a great and simple project.
The link Marra suggested are the most important.
Here is a decently-illustrated thread - B1 preamp build thread
Unfortunately no. But the best thing is to learn to work from a schematic. BUT that's not always possible as you need to take things like lead spacing into consideration... Look at various threads on the B1, and you will start to see how other people put them together.
Also do not hesitate to ask for assistance on the threads! Lots of people here who are willing to help. That's what the forums are all about
Old 2nd January 2013, 12:36 AM   #630
Thanks everyone & Happy New Year! When I said I was starting from scratch I really meant it! I'll have to buy an iron and read up on the resources posted above, I'll report back soon.
B1 builders threadHide this!Advertise here!
F3 Builders Thread Melon Head Pass Labs 622 10th January 2018 06:10 PM
ezDAC v.1.5 Builders Thread ezkcdude Digital Line Level 366 14th March 2013 03:31 PM
A-X IP Issues (split from Builders thread) tomchaoda Pass Labs 107 16th October 2011 02:05 AM
one for the box builders offroadbum Car Audio 2 11th October 2004 09:19 PM
