B1 builders thread
B1 builders thread
Old 23rd December 2012, 05:27 PM   #611
voxxonline is offline voxxonline  United Kingdom
voxxonline's Avatar
B1 builders thread
Will see, because I will be connecting lighter note to b1, and will have one digital source only.
Thank you very much . Will test it tomorrow with jumpers.
How to find time to finish my projects ?
Old 23rd December 2012, 05:28 PM   #612
6L6 is offline 6L6  United States
6L6's Avatar
B1 builders thread
Cheers and good luck!
Report back with your results!
Old 23rd December 2012, 05:37 PM   #613
voxxonline's Avatar
B1 builders thread
Will do
Merry Christmas
Old 24th December 2012, 08:52 AM   #614
voxxonline's Avatar
B1 builders thread
BTW Gents, using a multimeter in this case- to check inputs for switch...
Which values or what I supposed to get ?
This is that I am still missing- how to troubleshoot assembly using multimeter
I just need to check which combination gives me positive voltage and which has no voltage across ?
Old 24th December 2012, 02:21 PM   #615
6L6's Avatar
B1 builders thread
Yes.
Does your meter have a beep function where it will make a tone if there is continuity? If not just use ohms and look for no or very, very little resistance as proof of continuity.
You need to start from the input pads and determine to which of the switch pads they connect.
Then once you know where the inputs connect to the center switch pad, connect the inputs you wish to use to the center pads on their respective sides.
Old 24th December 2012, 02:55 PM   #616
voxxonline's Avatar
B1 builders thread
I have continuity - will check it now.
One of my capacitors next to the power input (2 big black ones) has voltage half another one- 8 vs 16. Is this normal ?
Old 24th December 2012, 03:04 PM   #617
6L6's Avatar
B1 builders thread
Yes, I recall that's the way the fets bias or something like it.
If your connections are good from the input to the switch pads and then to the wiper of the pot (the center connections of the potentiometer) then you should fire it up again and see if it works!
Old 24th December 2012, 03:20 PM   #618
voxxonline's Avatar
B1 builders thread
It works
All seems to be good.
Can start with psu for b1 and lighter note...
Thank you very much
Resistor colour coding is the task, as my multimeter out of range for some of them ...
Old 24th December 2012, 03:27 PM   #619
6L6's Avatar
B1 builders thread
Great to hear! Congratulations!
What do you mean your meter is out of range for some? If it's not an auto-range meter it will have choices for ohm range...
Also I highly suggest buying a good auto-range meter. If you buy a good one it will last forever and be a good help on many projects, not only DIY audio! I like Fluke.
Old 24th December 2012, 03:39 PM   #620
voxxonline's Avatar
B1 builders thread
For now I have simple ebay mmeter.
Some of resistors for lighter note do not give any value, even then I switch between resistance on multimeter.
I will try again, maybe it is just me
I have question- connecting lighter note to b1 better from the source side or directly into the place of the volume pot ?
B1 builders threadHide this!Advertise here!
F3 Builders Thread Melon Head Pass Labs 622 10th January 2018 06:10 PM
ezDAC v.1.5 Builders Thread ezkcdude Digital Line Level 366 14th March 2013 03:31 PM
A-X IP Issues (split from Builders thread) tomchaoda Pass Labs 107 16th October 2011 02:05 AM
one for the box builders offroadbum Car Audio 2 11th October 2004 09:19 PM
