#601 |
I was testing 1 channel only as I wasnt sure about assembly:
cd player- 1 channel (left) to input (red to signal green to gnd) out -(as well only 1 channel-left) , red- signal green- gnd. I ll make pictures shortly . |
#603 |
The pin (center) of an RCA (cinch) is the +
The outside bit is the ground. You have your signal on the common ground, and thereby connected. EDIT - when you get it connected properly, you will likely have no signal, as there is no connection at the selector switch.
llustrated Build Guides - Pass Pearl 1 - Pass B1 - - Pass F5 - Pearl 2 - -O2 HPA - - Pass F4 Last edited by 6L6; 23rd December 2012 at 04:38 PM. |
#604 |
How to put jumpers properly for now to have a signal from one of the inputs ?
Thank you very much |
#605 |
I'm looking at the photo and am getting more confused. So I'm not going to make a recommendation. The switch logic is not looking correct to me, although I am probably looking at it wrong.
Did you kit come with instructions and/or a switch or switches for that position? |
#606 |
No, apparently it is solely based on original b1, so instructions are from there.
Kit has no switch. I can recall similar problem on audiocircle.com, maybe I can track the same thread about switch.. If no result I ll get original b1 pcb... |
#607 |
Use a multimeter to check which input goes to which pad on the S100/S200 connections near the middle of the pcb then solder a link to the middle solder pad should do it. The middle ones should be the ones that connect to the potentiometer. I would recommend 63/37 rosin core solder; don't use lead free.
#608 |
On the set of 3 pads marked, respectively, S100 and S200, you will need to connect the center pad to one of the outside pads. There are not that may combinations to try.
If you have a SPDT switch just connect it to one set of the pads, one switch position will work. If you have a DPDT that will work as well |
#609 |
#610 |
I agree.
Do you plan on having more than one input? If so you will need 2 DPST switches. But for now connect R2 to center and L2 to center. |
| ezDAC v.1.5 Builders Thread | ezkcdude | Digital Line Level | 366 | 14th March 2013 03:31 PM |
| F3 Builders Thread | Melon Head | Pass Labs | 498 | 20th December 2012 12:31 AM |
| A-X IP Issues (split from Builders thread) | tomchaoda | Pass Labs | 107 | 16th October 2011 02:05 AM |
| one for the box builders | offroadbum | Car Audio | 2 | 11th October 2004 09:19 PM |
