Old 2nd February 2012, 02:50 PM   #521
KatieandDad's Avatar
OK found it. I'm now posting in right thread.
I will have a complete B1 available for anyone that would like to try it.
It's BRILLIANT - It's just my DIY bug that won't let go. It won't have the Oblligatos fitted, it will be back to 2 x 4.7uF Polyprop drops as it started life.
This is a DIY board but is fully functional and has been thoroughly tested.
Old 2nd February 2012, 02:58 PM   #522
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Post that in swap meet, not in regular threads.
Old 24th May 2012, 09:06 AM   #523
sachu888's Avatar
Here is my B1 with LDR volume control and DIY regulated power supply:
Click the image to open in full size. By sachu888 at 2011-12-24
Click the image to open in full size. By sachu888 at 2012-03-03
Click the image to open in full size. By sachu888 at 2012-03-02
I am very happy with the sound.Thanks Mr. Pass for sharing great designs to DIY community.I have one problem with this setup Bass is sounding very thin with LDR volume control.Can anybody comment on this?Can buypassing LDR or replacing it with 47k stereo Pot will solve this issue?
Sachin
Old 26th May 2012, 08:40 AM   #524
OlavHaal's Avatar
Default Hi there - with thin bass
On my B1 - which have very firm bass and good sound - I used a variant of this - that I found on the ebay. There are many versions and prices if you look closely! I think your cat5 single wire is much too thin in this amplifier.
Valab 16 AWG (19 x 0.32mm) Teflon Silver Plated Copper Wire
Best
Olav
File Type: jpg $(KGrHqF,!pEE8WR)eYBwBPKYfz68n!~~60_57[1].jpg (243.6 KB, 74 views)
Old 26th May 2012, 10:42 AM   #525
What is the difference in resistance of a Cat5 pair to your Valab pair at 1m and 10m interconnect lengths?
What proportion of the total circuit resistance is made up by the cable resistance change?
Do the differences in impedance of the cables account for some of the sound difference?
regards Andrew T.
Old 26th May 2012, 02:34 PM   #526
Î see that you put the gate and source to ground. In the article of Mr. Pass, he says to put the gate and drain to ground. I am confused....
Old 26th May 2012, 02:39 PM   #527
6,
post the reference.
gate and source connected creates a CCS
gate and drain connected creates a test topology.
regards Andrew T.
Old 27th May 2012, 01:22 AM   #528
The reference is from the b1 preamp pdf you can download at http://www.passdiy.com/pdf/B1%20Buffer%20Preamp.pdf. On the page referenced as SIDE C, the second last paragraph, it states the following: <<Q101 and Q201 are constant current sources formed by simply attaching the Gate pins of the JFETs to the Drain pins. They provide without loading
them down or creating significant distortion.>>. This is why I am asking the question.
Old 27th May 2012, 03:26 AM   #529
sachu888's Avatar
Sorry6,but I did not understand your query.
Sachin
Old 27th May 2012, 09:39 AM   #530
I just want to know what is the correct way to wire up the transistor. I see that you wired the transistor a certain way and Mr. Pass another to make a current source. Maybe its a typo in the article but which one is correct?
F3 Builders Thread Melon Head Pass Labs 459 28th May 2012 09:47 AM
ezDAC v.1.5 Builders Thread ezkcdude Digital Line Level 349 9th February 2012 07:05 PM
A-X IP Issues (split from Builders thread) tomchaoda Pass Labs 107 16th October 2011 02:05 AM
one for the box builders offroadbum Car Audio 2 11th October 2004 09:19 PM
Page generated in 0.08872 seconds (79.62% PHP - 20.38% MySQL) with 11 queries
