B1 builders thread
B1 builders thread
Old 14th January 2012, 03:32 AM   #401
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
B1 builders thread
I would advise 95dB+ speakers when able to make or buy for your room size and gain structure.
Old 14th January 2012, 03:47 AM   #402
buzzforb is offline buzzforb  United States
buzzforb's Avatar
When going balanced, I think the BA-3 goes up to 30db of gain. That should be sufficient. Nelson says in article that standard is 30, but some have suggested more along the lines of 10-12dB . My room is 16 x 16 and open on right side, but I have no problem reaching uncomfortable volume levels. The greater appeal of higher efficiency speakers for me is the operation of my amps at lower power levels and corresponding distortion levels. 95dB is horn territory. What do you listen to. Running your pre ahead of BA3 will give plenty of gain,correct. I could always pull the F5 back out, but i just like this one better.
Old 14th January 2012, 05:30 AM   #403
bassnkeys is offline bassnkeys  United States
Default Holy Grail
Originally Posted by buzzforb View Post
I really appreciate the suggested reading. I may have mislead you with my explanation of the sound of the DCB1. Using my current setup of DCB1->BA3 FE->BA3 output with Renasas laterals, the sound is excellent, with wide soundstage, pinpoint imaging, and excellent dynamic range. The laterals have a very natural and musical tone that i love. They do not have any forward bloom and this is my only gripe. If i change the BA3 output to my second copy with IRF fets, i get a more forward sound,but sacrifice tone, imaging and seperation. They both have their merits, but i prefer the lats. I am going to spend some time trying to tweak them. I believe it is very possible to improve the final sound. I think the phase is a non issue,but admit that i am a noob and heed advice given by others. It is something i will be more aware of now.
If you're getting nice separation (big soundstage) along with imaging and dynamics I guess you are about there!
I am professional musician and may be able to suggest some sweet stuff to listen to on that rig. Where do your musical interests lie?
Old 14th January 2012, 10:18 AM   #404
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
Well, Phase one of the rebuild is now complete.
I have replaced the Capactive Multiplier with a CRC combination and the 15VA EI transformer with a 30VA Toroid.
The sound is still "BLACKER than BLACK", but it does seem to have livened up a bit.
I'm still using the LM317 regulator.
Could the reduced impedance of the 30VA and CRC driving the regulator make that much difference ?
There's always the factor that we all want to hear improvements when we are "playing".
Old 14th January 2012, 10:21 AM   #405
Reduced supply impedance can make it sound different.
Reduced noise passed from Mains to buffer can make it sound different.
regards Andrew T.
Old 14th January 2012, 10:29 AM   #406
I've been very careful with mains filtering but I know there is a difference in the way that EI and Toroids isolate mains born noise.
I've got a mains filter at the input. Pinched from an old VCR. This is two bi-filar toroids and two X caps .
After the TR / Bridge I've got 4700uF + 2R2 + 4700uF then it goes to the regulator.
The result is a BLACK silence that I am more than happy with.
If Capacitive Multipliers were the answer to smaller caps, everyone would be using them ????
You might recall the original image ?
Old 14th January 2012, 10:41 AM   #407
buzzforb's Avatar
Tend to favor jazz, classical, rock, and folk. Ill take any recommendation. Pm m eor share freely!
Old 14th January 2012, 10:44 AM   #408
buzzforb's Avatar
Some would argue that the lm317 has a sound. Bypass it and see if you think so. Try using it as a current vs voltage regulator. I just discovered this difference, although i have not listend to it yet
Old 14th January 2012, 10:49 AM   #409
The input to the reg is 30V
I've run the B1 at 28V - will it still be OK at 30V ?
All the caps are rated well above 30V.
Old 14th January 2012, 11:05 AM   #410
buzzforb's Avatar
Pass says they can take up to 32. Have you tried running them at spec'd voltage?
B1 builders threadHide this!Advertise here!
F3 Builders Thread Melon Head Pass Labs 622 10th January 2018 07:10 PM
ezDAC v.1.5 Builders Thread ezkcdude Digital Line Level 366 14th March 2013 04:31 PM
A-X IP Issues (split from Builders thread) tomchaoda Pass Labs 107 16th October 2011 03:05 AM
one for the box builders offroadbum Car Audio 2 11th October 2004 10:19 PM
