#181 |
if you already have the speakers and the amp then adding a B1 is cheap. You can breadboard it as an experiment. To check gain, just use a passive pot, it will have the same maximum volume as a pot + B1 |
#182 |
#183 |
No Andrew T
I don't have the amp Just the speakers I wanted to build the combo (B1 + F5) ik |
#184 |
Borrow a 25W to 30W amplifier and listen to your speakers at home at the levels you like.
#185 |
endrik35 -- Your build is beautiful! Very well done!
May we see some photos of the inside? Question - what did you do to make the "Pass" logo on the front? It looks nice. |
#186 |
#187 |
Finally my turn to post pictures of my complete B-1. It is a balanced version (or RCA) and it uses 2 DRV-134 (Per Anders PCB) to convert the RCA signal to XLR. A word of caution: I had to use 2 separate transformers to get the DRV-134 to work with the B1.
Cheers to all, Eric |
#188 |
6L6,
I apologize if I missed in this thread or your build thread but where did you get that chassis from for your B1? Thanks. James |
#189 |
I got it from a friend, who in turn bought it from a now-defunct supplier called (I think...) DIY hifi enclosures.
Look to Par-Metal or Modushop for nice enclosures. |
#190 |
Thank you.
James |
| ezDAC v.1.5 Builders Thread | ezkcdude | Digital Line Level | 366 | 14th March 2013 03:31 PM |
| F3 Builders Thread | Melon Head | Pass Labs | 498 | 20th December 2012 12:31 AM |
| A-X IP Issues (split from Builders thread) | tomchaoda | Pass Labs | 107 | 16th October 2011 02:05 AM |
| one for the box builders | offroadbum | Car Audio | 2 | 11th October 2004 09:19 PM |
