B1 builders thread - Page 18 - diyAudio
Old 8th February 2011, 06:34 PM   #171
AndrewT is online now AndrewT  Scotland
insert a resistor in the power feed and measure the current.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 8th February 2011, 06:55 PM   #172
Default B1 current
will do,
thanks
Old 8th February 2011, 07:14 PM   #173
Originally Posted by 6L6 View Post
Try the RCA first, and see how it sounds (I.E., hum) It there is a problem, then try on the pot.
thanks 6L6 i do that..
i tested the build the other day but i did not include the 1M resistor (i forgot it). It seemed to sound fine.. this was only using a mp3 player as a source.
So is the 1M necessary for all sources? Just curious i will be putting them in..
Old 8th February 2011, 07:18 PM   #174
6L6 is offline 6L6  United States
6L6's Avatar
I think it's more of a ground loop breaker... I'm not entirely sure, actually.
Old 8th February 2011, 09:25 PM   #175
Default B1 current draw
Didn't check the current yet but did look at power source (pair of 9v batts)
18v off the batteries becomes 9v at the board power in location
Old 8th February 2011, 09:42 PM   #176
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
Some very nice looking stuff in here guys Keep it up!
Old 9th February 2011, 07:43 PM   #177
thought i would share a couple of pis of my build.
I decided to go point to point and integrate am mp3 player into the unit... not quite finished, i have to finish mounting the mp3 player and add the faceplate to it and the feet and knob are temporary for the pics also considering adding some leds to give it a glow but not sure yet..
Old 10th February 2011, 01:08 PM   #178
Hi all,
I'm very interested in the B1 and F5 combo.
But before beginning would like to know if it can drive my naim SBL to satisfactory levels
their sensitivity is 89 and impedance 6 ohms
and I have a mid size space (6X7 meters)
thanks
IK
Old 10th February 2011, 01:22 PM   #179
the B1 & F5 have a gain of +15.5dB.
The signal level at the B1 input needs to be higher than usual. 3.5Vpk for maximum output. A CDP is normally capable of ~3Vpk at maximum.
The 27W into 8r0 becomes ~36W into 6r0.
This will give a maximum of ~100dB SPL at 2.5m from a pair of 89dB speakers.
In a 42 sqm room, I would not consider that sufficient.
regards Andrew T.
Old 10th February 2011, 04:28 PM   #180
thanks for that Andrew T
What a disapointment !
So what would you recomend for a 1st time DIY? (an active pre?)
I would realy like to try using the F5 for amplification
IK
F3 Builders Thread Melon Head Pass Labs 523 31st May 2014 04:05 PM
ezDAC v.1.5 Builders Thread ezkcdude Digital Line Level 366 14th March 2013 04:31 PM
A-X IP Issues (split from Builders thread) tomchaoda Pass Labs 107 16th October 2011 03:05 AM
one for the box builders offroadbum Car Audio 2 11th October 2004 10:19 PM
Copyright 1999-2017 diyAudio
