B1 builders thread
B1 builders thread
Old 22nd May 2010, 08:53 AM   #121
westend is offline westend  United States
A little premature, on my part. I am missing a couple of components so haven't powered it up but here are some chassis efforts.
Old 22nd May 2010, 11:17 AM   #122
bigaudioscotto is offline bigaudioscotto  United States
That is a Good looking chassis,did you fabricate it yourself.
Old 22nd May 2010, 12:38 PM   #123
Do any of you guys know how to wire
B1 for Sub out.
Old 23rd May 2010, 03:50 PM   #124
ppcblaster is offline ppcblaster  United States
Default Maybe this will help.
B1 for Sub out.
http://www.diyaudio.com/forums/subwo...annel-amp.html
Old 23rd May 2010, 03:52 PM   #125
I see two knobs, did you use two volume pots instead of a single dual pot?
I didn't think of that, it would have the added feature of balance control.
Old 24th May 2010, 12:14 AM   #126
Yes I did. You can PM me for infomation about it.
yes, they are Alps mono pots. There was discussion on the B1 main thread about the use of stereo or mono and gain control so I thought I'd use two monos.
Old 24th May 2010, 02:24 PM   #127
massimo is offline massimo  Italy
We might be interested as well..... if you can share those info, other people might appreciate.
Old 25th May 2010, 01:39 AM   #128
chemania is offline chemania  United States
Anyone have any experience with very heavy bass output in the B1? I am running a 50k blue velvet as my volume pot and stuck with the values NP gave in the article....his board btw... and the bass is overpowering. Everything else seems to sound fine. It has at least twice the bass as my BOZ. Which I consider to my "neutral" reference right now. It replaced my YBA 3 preamp. Any thoughts as to why I have so much stinking bass?
TNX
Old 25th May 2010, 03:35 AM   #129
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
B1 builders thread
Is it possible your previous preamp had an early rolloff when coupled to your amp, for low freq's and the B1 when coupled to your amp is essentially flat down to a much lower freq? It could be you have too much baffle step compensation in your speakers (or they are close to walls/corners) and the previous preamp was rolling off early and compensating for this, but the B1 is not, so it now stands out.... If you have a way of doing freq response measurements of the whole chain (eg using truerta) This could give you the answer.
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 25th May 2010, 06:07 AM   #130
fishski13 is offline fishski13  United States
x2. love the chassis and Kilo knobs.
B1 builders threadHide this!Advertise here!
F3 Builders Thread Melon Head Pass Labs 622 10th January 2018 06:10 PM
ezDAC v.1.5 Builders Thread ezkcdude Digital Line Level 366 14th March 2013 03:31 PM
A-X IP Issues (split from Builders thread) tomchaoda Pass Labs 107 16th October 2011 02:05 AM
one for the box builders offroadbum Car Audio 2 11th October 2004 09:19 PM
