Old 28th April 2010, 01:41 AM   #101
t3447ml is offline t3447ml  United States
The regulator board from from a Bob Ellis group buy: Scalable PSU/regulator GB
You are correct about the pot, it is 10k and I'm looking for a good 25k replacement.
Old 28th April 2010, 02:41 AM   #102
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
alps black beauty, i got mine on ebay i bought 2 because i want to compare the B1 with it, and just a passive pot!
Old 28th April 2010, 05:13 PM   #103
cjkpkg is offline cjkpkg  United States
OK...got the distortion issue sorted out... ***Ahem*** miiiight have put a zener diode in the board instead of the 1n*** type....***Ahem***...
Got it all pretty well stuffed in the Hifi2000 galaxy chassis. Might have to trim some wires though. And I still need to mount the board to the bottom plate.
It is dead quiet and does sound nice. The only thing I wish is that I could get a little more gain out of the F5. With the B1 wide open it is just slightly less than my ideal - home alone - loud listening level. For 90% of the time it would be fine.
Old 29th April 2010, 09:06 AM   #104
Yes, a B1 feeding an F5 gives a total voltage gain from source to speaker of 6times (+15.5dB).
This converts a CDP signal of 2.2Vac to a maximum of 13.2Vac at the speaker. Needs quite high efficiency speaker to play loud.
regards Andrew T.
Old 29th April 2010, 12:59 PM   #105
Indeed...hooked the B1 up to my chipamp.com LM3886 and it sounded fantastic...
Old 1st May 2010, 08:37 PM   #106
More progress...I mounted the PCB and JBwelded the power inlet to the floor of the chassis...
Old 3rd May 2010, 07:08 PM   #107
Marra is offline Marra  United Kingdom
My humble but great sounding B1. The pcb is up on stilts and C2mounted underneath because I forgot about the caps diameter; with the lid on who'll know.Hope this works.
Old 3rd May 2010, 07:28 PM   #108
The inside.
Old 3rd May 2010, 07:38 PM   #109
Sorry about the quality of the pictures
Old 8th May 2010, 06:04 AM   #110
lots of great builds.
here's my B1. DIY chassis with sanded aluminum and tung-oiled sapele. connectors are Switchcraft, wanky wire is Cardas, Clarity Caps, and a PEC pot. the 24V PS is an o-11 from AMB Labs AMB Laboratories DIY Audio Site in a Hammond black anodized chassis. the 10mm LEDs illuminate the interior and serve to indicate if the output is to speakers (blue), or muted and line-out to a headphone amp (slutty red) via the 3PDT switch on the front. i also installed a pair of RCAs for a subwoofer-out.
sounds fantastic "driving" my Amp4 and uFonkens^2. i just need to finish my F5 now .
a big thanks to Nelson to sharing his knowledge and time, and to everyone else that contributes here at diyaudio.com.
F3 Builders Thread Melon Head Pass Labs 459 28th May 2012 09:47 AM
ezDAC v.1.5 Builders Thread ezkcdude Digital Line Level 349 9th February 2012 07:05 PM
A-X IP Issues (split from Builders thread) tomchaoda Pass Labs 107 16th October 2011 02:05 AM
one for the box builders offroadbum Car Audio 2 11th October 2004 09:19 PM
Page generated in 0.08568 seconds (70.36% PHP - 29.64% MySQL) with 11 queries
