#41 |
Formerly Thanh1973
Very nice work modster
Those motor run caps, I see in the amp. Is there a significant audible improvement using them? I have some 10uf wima caps laying around but I am considering buying some 100uF motor run polypropylene capacitors. Is it worth it putting them in?
"No, this sucker's electrical, but I need a nuclear reaction to generate the 1.21 gigawatts of electricity I need." Last edited by Melon Head; 2nd November 2009 at 09:22 PM. |
#42 | |
my workis always like that - when I'm actually makin anything for serious ( not counting Bonsai/Ikebana prototypes ) ![]() motor runs are there from two serious reasons : 1. they give you serious improvement in "snap" of sound 2.they're much cheaper and much more potent than usual audiophool solid caps ...... and - in same time at least of same quality , if not even better ; they are , at last , of industrial quality ; our preferable brand is Icar Italy talking about amps - look at picturte of another one - made under same circumstances - pcbs and work are mine , everything else is - of less skilled Serbian DiYA member so - previous one is completely dual mono : 300VA donut , 2 secondaries through 2 discrete Shottky Graetzs ,4x33mF/25V Panas , 2x50uF Icar caps per channel this one is one 600VA donut for both channels (two secondaries) , then 2 discrete Shottky Graetzs 4x33mF/25V Panas and zx50uF Icar caps per channel ; so - only donut is shared between channels I can't hear any significant difference between these two , even if that pure dual mono have silver cabling for input and preputium Monster cabling for speaker edit - just disregard unusual amount of usage of term "serious" in this post
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#43 | |
.....but if you're put of by 30$ a piece, the DIY version is going to give you a stroke! Magura
Everything is possible....to do the impossible just takes a little while longer. www.class-a-labs.com |
#44 |
Formerly Thanh1973
I believe the biggest improvement comes from having separate power supplies per channel not neccessarily transformers, just the way you have done it.
Also 2 x 300VA transformers take up more space than a 600VA transformer, so unless you are doing monoblocks (ie separate amp cases), then I would also do it your way. Just go with the biggest transformer you can afford, and then go with separate rectifiers and power supplies per channel. Thanks for the info regarding the caps. I will buy some and let you know what I think.
"No, this sucker's electrical, but I need a nuclear reaction to generate the 1.21 gigawatts of electricity I need." |
#45 | ||
Significant ? so there is a difference ..... Quote:
#46 |
Formerly Thanh1973
I think what he was trying to say, is that the difference is so insignificant that he can't tell which sounds better.
So while there maybe a difference, it may not necessarily be in the dual transformers favour. The room that 2 x 300Va transformers take up, could be used to fit a single 1000VA transformer. I know which one I would take if you were trying to fit your amplifier into one case.
"No, this sucker's electrical, but I need a nuclear reaction to generate the 1.21 gigawatts of electricity I need." Last edited by Melon Head; 3rd November 2009 at 12:20 AM. |
#47 |
#48 | |
Dont forget they are intended fore relative simple and sensitive speakers If you dont need the exstra power, huge "monsters" doesnt always sound better, or maybe even worse |
#49 |
blue led for blues of Babelfish J by ZM screen
#50 |
bank of VT4C , attached for pcb , is in other room
| s/500 dual to mono | joegio | Pass Labs | 3 | 27th April 2009 12:12 AM |
| making dual mono jack from single mono jack | dubmunkey | Analog Line Level | 2 | 12th October 2006 02:16 PM |
| My Zen V4 Dual Mono | wchick | Pass Labs | 37 | 11th November 2002 09:54 PM |
| Single Mono's or Dual Mono? | Tazzy | Pass Labs | 8 | 3rd October 2002 02:03 PM |
| Dual Mono - Anti Mono Power Supplies | pmkap | Everything Else | 3 | 16th February 2002 05:10 AM |
| Page generated in 0.12555 seconds (79.64% PHP - 20.36% MySQL) with 11 queries |
