Zen headamp. PCB, my ver.
Old 28th October 2009, 07:21 PM   #1
Stream is offline Stream  Russian Federation
Stream's Avatar
Send a message via ICQ to Stream
Default Zen headamp. PCB, my ver.
Hello. I'm interested in building Zen head-amp and now designing PCB for this.
My PCB design is based on Marcello Pellerano's PCB, which can be found here:
HeadWize - Project: The Zen Headphone Amplifier by Marcello Pellerano
So here is my version. It's a bit smaller then "original" and I also tried to minimize the total length of tracks, were signal is flowing...
Waiting for comments and advices.
After all I'll share Eagle file here.
Old 28th October 2009, 08:50 PM   #2
twitchie is offline twitchie  Burkina Faso
Maybe flip R3 and R10 and eliminate the jumper, then you could also straighten up the track between R10, R11 and Q2
Old 28th October 2009, 09:57 PM   #3
mosconiac is offline mosconiac  United States
Great suggestion, twitchie.
Old 29th October 2009, 12:32 AM   #4
Melon Head is offline Melon Head  Australia
Banned
If you have LU1014D jfets and if you don't already have your heart set on this design, then I would seriously consider something like Patrick's DAO Headphone amp.
Old 29th October 2009, 02:24 AM   #5
Bigun is offline Bigun  Canada
Bigun's Avatar
If you can make it small enough, put both channels on one board ?
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 29th October 2009, 12:29 PM   #6
Rodeodave is offline Rodeodave  Austria
hates ground loops
Rodeodave's Avatar
Concerning C2: Maybe add more holes to support various footprints/sizes.
Gravity - Making the G since 13.7 billion B.C.
Old 30th October 2009, 08:03 PM   #7
Stream's Avatar
Twitchie,
Done. Thank You.
Rodeodave,
Added Lead spacing 10.2 and 15mm. Need any more?
PCB size is ~85*72mm (with mounting holes)
Inputs cap (C2): Wima MKP4 or other (LS 10.2, 15, 22.5 mm);
Output caps (C9,C10): Panasonic FM 470uf or another (LS 5mm); Elnas are too big
Power Cap (C6): Panasonic FC or other ( LS 7.5mm)
Bigun,
It will be dual mono, so both channel will be just this PCB*2. Maybt I'll made stereo version later (but to be honestly, I'm not realy interested on this )
thanh1973,
I have read about DAO, and I even believe, that it's better then ZEN (lol), but:
1. DAO need bigger enclosure, bigger filter caps, bigger trafo... Maybe next time
2. I'm afraid I need some voltage gain...
3. There aren't any complete Guide for DAO amp, and my skills are not good yet, I'm DIY noob
Old 30th October 2009, 09:15 PM   #8
Banned
2. You can get all the voltage gain, you need with a suitable preamp.
3. OK, but I am sure EUVL would walk you through it, with pcb, etc.
In the end though build what you feel comfortable with. I am sure you will be happy with the result
Old 31st October 2009, 03:20 AM   #9
Banned
The only thing I would probably do differently, with this design, is I would remove the active bias circuit.
A headphone amp really doesn't need an active bias circuit, I would bias it between 600mA to 1A. This will sound better than lowering the bias down with the active bias circuit.
The main benefit I see for the active bias circuit is you can use smaller heatsinks.
Old 1st November 2009, 12:57 AM   #10
EUVL is offline EUVL  Europe
That depends on the bias you want to run. I have a version running at +/-16V, 100mA. and you don't need much heatsink for that.
Not if you have low impedance phones (e.g. AK701).
That is true, I am too lazy / busy with other projects .....
But I am sure Steen or James would help you.
There isn't really much in the circuit, especially the original version.
But then who am I to tell you to build the DAO instead of Nelson's designs !!
Patrick
Zen headamp. PCB, my ver.Hide this!Advertise here!
Downscaling Zen v.9 for use as headamp kenev Pass Labs 34 12th April 2010 02:06 PM
MC headamp with opa PTSOUNDLAB Analog Line Level 1 11th January 2008 10:56 PM
It's my AD815 headamp Kochkurov Maxim Chip Amps 16 11th May 2006 12:44 PM
Pocket pre-amp & headamp digi01 Chip Amps 11 10th October 2004 01:49 AM
headamp with pre-out [3pic] digi01 Chip Amps 2 24th September 2004 03:54 AM
