Zen headamp. PCB, my ver. - Page 5 - diyAudio
Old 19th February 2013, 08:14 AM   #41
Gregje is offline Gregje  United Kingdom
Will do. I am at work now...
Old 19th February 2013, 07:50 PM   #42
Hi 6L6,
here are two pictures of my Zen HP amp.
The amp PCBs are mirror images of what you normally see with this amp. I haven''t realized that the files I was using were seen from the elements side. But I have changed the connections to the transistors terminals obviously.
Is it crucial in this design to star connect all the grounds? I was also planning to use shielded cables everywhere for the signal connections.
The power supply is about 20V.
Many thanks,
Greg
Old 24th February 2013, 10:07 AM   #43
My bigger caps have not arrived yet. In the meanwhile I tried a regulated PS.
I used some 78xx I had lying around. I used 5k pot to set the ground voltage seen by the regulator. I lost some 2V of the output of the PSU but there is no hum whatsoever.
Still evaluating, but this might be a better solution for me that the caps.
Old 21st May 2014, 08:28 AM   #44
I was browsing some old posts recently.
This one need clarification on my side.
The hum I was complaining about was coming from a ground loop (I did not expect it in that place). So it was my fault. The amp is now pretty quiet using my HD595. I have somewhat more (but not much more) capacitance in the power supply.
Now it sounds more like I expected it to sound when I stared the project.
The sound has changed dramatically.
Greg
Downscaling Zen v.9 for use as headamp kenev Pass Labs 34 12th April 2010 01:06 PM
MC headamp with opa PTSOUNDLAB Analog Line Level 1 11th January 2008 09:56 PM
It's my AD815 headamp Kochkurov Maxim Chip Amps 16 11th May 2006 11:44 AM
Pocket pre-amp & headamp digi01 Chip Amps 11 10th October 2004 12:49 AM
headamp with pre-out [3pic] digi01 Chip Amps 2 24th September 2004 02:54 AM
Copyright 1999-2017 diyAudio
