Zen headamp. PCB, my ver. - Page 3 - diyAudio
Old 17th November 2009, 04:00 PM   #21
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
This could also be used as a pre-amp maybe.
Old 18th November 2009, 05:07 AM   #22
tortello's Avatar
Originally Posted by Stream View Post
Tortello, can You confirm this?
Hello,
yes, if you want you can put a potentiometer instead of the pot+res series, set the bias (and the balance), measure the potentiometer resistance value and then swap the pot with a fixed resistor. More compact circuit and more long-term reliability!
As for a preamplifier, I do prefer the "classic" BLS! IMHO it's great!
Best,
Marcello
Old 27th November 2009, 03:02 PM   #23
Stream is offline Stream  Russian Federation
Stream's Avatar
Send a message via ICQ to Stream
Hello, It's me again
I hope this is the last or pre_last version. I'm only thinking on those resistors before pots, I;m not sure It was realy good idea to cut them out
I'm not sure I can make this PCB with Laserprint method, it's too complex, but I'll try.
P.s. Tortello, do You remember in what range does pot R16 (100k) change BIAS? I's asking because You had 20k+100k resistance and I have only 100k now, so is it sufficient value to set 100-250ma BIAS.
Old 27th November 2009, 03:21 PM   #24
Stream's Avatar
OMG, I just killed 4 hours of my life - closed project and didn't save that (last save was 3.5 hours before)
Old 27th November 2009, 07:46 PM   #25
sorry to hear that Stream
Your layout looks great and you should have no problems etching with the Gootee method, I've done messier transfers
Old 27th November 2009, 07:56 PM   #26
Greg Erskine's Avatar
Hey Stream, redo it now while it fresh in your head. It never takes vey long the second time round. Most of the time in PCB design is working out what to do.
BTW: Wasn't auto backup on? Control panel > Options > Backup
regards
Greg Erskine
Old 27th November 2009, 09:12 PM   #27
Stream's Avatar
Greg Erskine
Whooh! My mistake was that I didn't start new project, I just Start new Board without Project, so Eagle for some reason doesn't save progress. But I found some files with *.b## extension, and after I rename this to *.brd it opened!
So here it is:
Brd:
http://rapidshare.com/files/313125268/ver7_finished.brd
Pdf:
http://rapidshare.com/files/313125486/ver7_finished.pdf
Old 2nd December 2009, 07:46 PM   #28
Stream's Avatar
Here is last version.
Changelog:
R8 removed
R17 1k => 2k
R4 came back. Because there are only 100k and 200k pots, and wee need about 120k.
A bit of cosmetic
Eagle brd File
PDF
Old 10th December 2009, 04:08 PM   #29
Stream's Avatar
+ Power Supply:
ver10_bridge.pdf
OOpps, found one mistake, correct soon...
Old 17th December 2009, 05:21 PM   #30
Stream's Avatar
Hello. Today I was a bit confused about one little thing - where should I connect gnd from output jack?
I just thought, that using 3-pin 6.3 Jack lowering advanteges of dual-mono architecture... Anyone can confirm this?
Downscaling Zen v.9 for use as headamp kenev Pass Labs 34 12th April 2010 01:06 PM
MC headamp with opa PTSOUNDLAB Analog Line Level 1 11th January 2008 09:56 PM
It's my AD815 headamp Kochkurov Maxim Chip Amps 16 11th May 2006 11:44 AM
Pocket pre-amp & headamp digi01 Chip Amps 11 10th October 2004 12:49 AM
headamp with pre-out [3pic] digi01 Chip Amps 2 24th September 2004 02:54 AM
Copyright 1999-2017 diyAudio
