Circlotron Meditations
Old 28th October 2009, 11:14 AM   #21
Ejam is offline Ejam  Australia
Default Power Supply
Nelson
Because I'm injecting power supply noise through the bootstrap resistor to the input signal?
Any suggestions to alleviate this aside from the "very quiet power supply", perhaps forgetting about bootstrapping.....
On the left mosfet I have the drain and source lettering around the wrong way, sorry about that.
Ejam
Old 28th October 2009, 01:49 PM   #22
mos57 is offline mos57  Italy
mos57's Avatar
Originally Posted by Ejam View Post
Francesco
If you look back at John Broskie's Tubecad musings he came up with an "inverted circlotron" circuit back in June 1999 where the output was taken from the drains giving both voltage and current gain. Anyway, thanks for the pdf, will get busy with my Italian.
Mike
Sounds good, when can we get a look at the details?
Ejam
Is the attached figure that you report?
Also if the load is connect from the drain sides, it isn't consequential to have voltage amplification.
Then, where are connected the input signals? I not view.
This is most relevant in this circuit to have gain voltage.
However, in this figure, if you look at the amplitudes of the input and output signal you can see that they are the same, so John not meant to show voltage amplification, i think.
Francesco
Old 28th October 2009, 02:32 PM   #23
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
No, the input is referenced to Ground, but the gain of
each Mosfet is referenced between the input and the +
rail of each device. Any noise in the supply will be amplified.
Old 28th October 2009, 11:18 PM   #24
Francesco
These are John's claims not mine, suggest you take it up with him.
Ejam
Old 28th October 2009, 11:22 PM   #25
Default Noise
Nelson can it be cancelled by feedback between the drain and the gate?
Old 29th October 2009, 01:28 AM   #26
The one and only
You need to avoid creating the problem - it is easier than
fixing it with feedback.
Look at an F5 for an example, where the input to the Mosfet
Gate is taken from the high output impedance of the Drain
of an input JFET so that you have some power supply
rejection.
Old 29th October 2009, 08:02 AM   #27
Nelson
OK so now its two stages instead of one, and around we go again. There is nothing like being poorly rejected by your power supply to dent your budding zen designer fantasies. See what Mark comes up with. To Zen or not to Zen that is the Pass enigma.
Francesco
By the way Francesco, cool amp, learnt a little about design and Italian along the way, hence it is the journey etc. etc. Is it possible to do away with the jfet stage, as I thought you said your amp was single stage only, not two. Probably not, same problem with power supply noise.
Old 29th October 2009, 11:30 AM   #28
mos57's Avatar
Originally Posted by kevinkr View Post
One of the very interesting claims in this patent relates to the fact that the output is ground referenced and from a dc standpoint there is no (dc) voltage present at the load. This is a big difference from the floating tube circlotrons I've worked on (and designed) in the past. (My last design had ground referenced outputs, but it was not the case that the outputs were exactly at ground potential - they could float some volts above or below but were common mode in theory at least.)
The topology also seems to allow for very convenient differential drive ground referenced from a balanced source or even a center tapped IT transformer.
Wonder how well it works. Built a working prototype? Pretty cool idea.
Thanks much for your appraisal.
Another great its advantage is in my mind, that people can drive this circuit with one unbalanced signal. How many people have balanced source in their set stereo?
Circlotron need 2 balanced input, so at the end it's necessary another phase splitter stage. How is good? how many is balanced and symmetrical? How to realize it? How other many parts need?
I think this last is very delicate on the final result over the same power stage.
At least with my referred circuit one people can save one stage.
Now about my patent.
People must understand that when look my circuit they not think as simply circuit stage, but as a "whole power amplifier".
0ne guy can put a source signal from his CD player or tape in the input amplifier and wired its output to the speaker.
Francesco.
Old 29th October 2009, 02:44 PM   #29
mos57's Avatar
Nelson
Francesco
Since the two bank of power supply are applied in opposite phase to the circuit (output terminal), also the power noise is in opposition, so you must match these last to cancel or lower the noise at the output.
Its not enough to put caps of equal value (their tolerances are high generally), but you must make a real measure of the two noise side.
Regards, Francesco.
Old 29th October 2009, 03:33 PM   #30
The one and only
Take a look at ZV5, which has the same situation on the
noise because the topology has many similairities.
Circlotron MeditationsHide this!Advertise here!
6S19 Circlotron (OTL) Fuling Tubes / Valves 62 13th November 2008 11:16 AM
Simple circlotron amp bigwill Tubes / Valves 4 18th March 2007 01:57 PM
Circlotron djk Pass Labs 13 20th August 2006 03:19 AM
6C33 Circlotron pat49hk Tubes / Valves 50 26th January 2006 09:06 AM
Supersymmetry Circlotron Circlomanen Pass Labs 6 18th April 2005 06:34 AM
