Pass "DeLite" Amp from BAF
Old 23rd March 2014, 11:14 AM   #801
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
that quote was for IRF and IRFP , so say regular mosfets
SSouths are different animals
Pa is using them in some FW products , wind up to 50W/piece , if we can believe what's written
so , keep it cool enough (palm rule) and let them bleed
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 23rd March 2014, 11:32 AM   #802
OllBoll is offline OllBoll  Sweden
Well, pushing one to 45 is much easier than fiddling with multiple nonmatched JFETs so I hope this is true =)
Old 7th April 2014, 01:57 PM   #803
Now I have one up and running but now there is that thump. I think I can do a passive solution by just reducing the onto put cap from 68mF (I know it was overkill but I had one lying around ) to 1mF. It's a midrange amp meant to cover 300 hz and upwards so the increased cap impedance isn't an issue.
My ccs is is an inductor so that would work because:
The thump is subsonic at 1 hz or below and down there the inductor impedance will be low and thus output impedance will be low. The output caps impedance will be high and thus the thump will discharge slowly and not be a problem anymore.
Or am I deluding myself and I need something more complicated than a smaller cap?
Old 7th April 2014, 03:20 PM   #804
Zen Mod's Avatar
easy to try , isn't it
small cap will not pass low thump
Old 7th April 2014, 05:55 PM   #805
True, and it seems to have worked =)
What once was a ~ 1cm movement on the speaker is now a tiny ~ 1mm so I don't think I have to worry anymore. I found I had a few bad solderings on the source resistors so that was why the resistance was too low, so now the bias is up to 2.35A, which is close enough to my goal of 2.5A so I'll settle.
Though this was a test, for the final I'll build 4 of them with 2 in each box so I'll probably redo it as the cabling is... not that beautiful at the moment =) And then I might as well stick a pot on it too so I can dial it to 2.5A =)
Old 13th April 2014, 02:53 PM   #806
Hmm, after some troubleshooting I've realized that the R085 really doesn't like high source impedances.
My Balanced to Single ended transformer (JT-11P-1) has 2.4k output impedance and I've used it until now in my F2J and L'amp without issues. The F2J has probably had some increased distortion high up because of it but it didn't make it sound bad at all, relaxed and nice all the way.
The DeLite with the R085 however, sounds awful when driven with a high source impedance and distorts a lot at 10khz +. There was about 15 dB more 2nd and 3rd and some higher order distortions starting to show up. The problem went away when I removed the transformer, so much more relaxing to listen to now =)
I guess I'll have to build a buffer if I want to use the transformer. The plan is to exchange the source with a single ended capable source so then I won't need a buffer which is nice =)
Old 14th April 2014, 12:12 AM   #807
One thing I've wondered about:
If I've understood correctly the output impedance of this circuit is the drain resistance of the R085 in parallel with the current source impedance. And so what I wonder is what is the drain resistance of an R085 at normal conditions of say 20V @ 2A.
In the end what I'm wondering is if I have a current source with high enough impedance will I get a pure current source amps of several hundred ohms in output impedance or will the R085 itself limit it to some number =)
Old 14th April 2014, 01:23 AM   #808
Zen Mod's Avatar
Originally Posted by OllBoll View Post
........ the R085 itself limit it to some number =)
Old 14th April 2014, 11:15 PM   #809
According to this post the output impedance is : Z=(V1-V2)/((V2/R2)-(V1/R1)) where 1 and 2 are voltage readings over different resistors.
I fed a 400 hz signal and got those readings:
V1 = 4.28V
R1 = 9.2Ω
V2 = 1.87V
R2 = 4.0Ω
So If I've understood correctly my output impedance is ( 4.28 / 1.87 ) / ( ( 4.28/9.2 ) - ( 1.87/4.0 ) ) = ~1000Ω.
If my calculation is correct that is. I expected it to be lower as the inductor impedance is only about ~377Ω then but if it it is that high then I'm not complaining =)
EDIT: Now it has 2.2Ω source degeneration, so that might be what is pushing up the output impedance. I want more gain though so I plan to mount bias supplies and then try with 0.33Ω and 0.66Ω and see how it performs. I assume that the output impedance should still be above 100-200 which should be enough.
Old 20th April 2014, 07:35 PM   #810
Now I've hooked up an inducted R100 again and compared somewhat. I'll have to echo Tea-Bags findings when he compared a R100 to an R085. The R085 sounds good, but isn't as easy on the ears as the R100. There is this brightness in the background that the R085 has that the R100 doesn't. Reminds me of when I compared my then inducted R100 to an NCore, which also had that brightness.
It probably has something to do with distortion, don't know what though. I've obviously used the R100 previously with too high source impedance causing lots of HF distortion but it still sounded relaxed and nice, where the R085 didn't sound nice at all. So there seems at least to me that there is some difference in the distortion characteristic between the R100 and R085.
Pass "DeLite" Amp from BAFHide this!Advertise here!
DIY Low Pass and Mid/High Pass (Bass Blocking) Filters runslikealpaca Everything Else 1 19th June 2009 10:59 PM
Paging Mr. Pass, Mr. Pass pull my finger please. khundude Pass Labs 2 5th December 2008 04:11 AM
Pass Tharagard A75 vs Pass Aleph 1.2's daly41k Pass Labs 7 18th February 2007 03:10 PM
Amperes of Pass amps & Pass for ESL rick57 Pass Labs 3 4th August 2005 03:28 PM
My opinion on Pass Labs and Mr. Pass (Nelson) himself b_online Pass Labs 11 21st May 2003 12:39 AM
