Old 3rd November 2011, 09:21 PM   #781
Originally Posted by vdi_nenna View Post
If not using light bulbs, can we call it the Zen Ten?
Jajaja , nice name
Old 15th December 2011, 09:47 PM   #782
Default Output Capacitor
In standard form, the ouput capacitor is sized at 10k uf, presumably
yielding a high-pass frequency in the single digits when used with
a nominal 8 ohm speaker. I'm considering assembling a stereo Delite
for some compression tweeters that are used with a passive
high-pass spec'ed to 1700hz. The first element in these 2nd
order high-pass filters is a 5 uf cap.
Is there any reason I could not put that cap in the amp in place
of the big electrolytic and connect the output to the coil that is
the parallel element in the crossover? I realize this would make it a
system-specific amp, but I am comfortable with this sort of thing.
Am I missing some impedance related issues that make this a
bad idea?
Thanks,
Skip
Old 15th December 2011, 10:04 PM   #783
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
just go for it , as long you remember that's "system specific amp "
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
Old 19th December 2011, 10:58 AM   #784
Skorpio is offline Skorpio  Denmark
Originally Posted by stefanobilliani View Post
And it works . Thanks a lot . So I set R5 1,47 for now , if it is correct probably we can also rise the rail Voltage to 40 volts or so
This looks familiar (my ZEN4). Would it be a worthwhile upgrade with the IXTH6N50D2 or would it be better to go for the power JFET (SJDP120R085)?
My idea is to drop the input buffer and biasing part completely and go for a Gate resistor of 47k and a source resistor...
Seems like nearly plug and play...
Old 19th December 2011, 05:10 PM   #785
The one and only
Nelson Pass's Avatar
The Source resistor will be a major player, since it is likely to be
several ohms to give you the bias you want. Of course you can
bypass it with a large cap if you need to.
Old 19th December 2011, 08:17 PM   #786
I tried the self biased R085 with a 1:1 OPT rather than the bulbs for a load. Needed about 2.5ohms source resistor with a +24V supply. Preferred the IXTH6N50D2 with 1ohm source resistor. Haven't tried bypassing the source resistor with the R085, that's a lot of uF ;-)
May try the R100 in there though....
Roscoe
Old 29th April 2012, 02:08 AM   #787
Pano is offline Pano  United States
Pano's Avatar
Default Dual Rail De-Lite
Hey guys,
I've been putting together a dual rail power supply version of the De-Lite. Same basic idea, same MOSFET even, but a +/- supply to eliminate the DC on the output. No cap or transformer needed on the output.
It's works pretty well so far using +/-12V and a 12V-27W automotive taillight.
Just wondering if anyone has a spice model of the IXTH20N50 MOSFET that would work in Microcap. It's the spice flavor I'm familiar with, so it would be handy for me. So far, I've haven't simulated it, just built it - but the sims might get me closer to my goals faster.
I think Nelson uses Microcap, right? Any chance for a IXTH20N50 model? I've searched but have not found. Thanks!
Take the Speaker Voltage Test!
Old 3rd May 2012, 11:08 PM   #788
Pano's Avatar
Nobody, eh? Too bad.....
Old 4th May 2012, 12:25 AM   #789
ra7 is offline ra7  United States
Pano, I'm interested. I had suggested earlier in this thread that a no-cap, dual rail version could be interesting. Do you have a schematic to share?
Although, I may not be able to help you on the simulation side.
Old 4th May 2012, 02:24 AM   #790
Pano's Avatar
Yep, there ain't much to it. See below. 12V and 12R is what I've been working with to start, but getting about 2A current flow may be the sweet spot. My 12V 25W bulbs can do that, but they are bright!
The idea is simple - as long as the voltage drop is the same across the MOSFET and the resistor (or bulb) then the node between them is at 0V compared to ground. Apply an AC signal and that 0V will fluctuate up and down. Voila - you've got an amp. To get the depletion mode MOSFET to drop the same voltage as the resistor/lamp, you have to turn it off a little. You want it to be the same resistance as the lamp. About 1V does it in this case.
There are some problems with this, but will go into that later, if anyone cares.
DIY Low Pass and Mid/High Pass (Bass Blocking) Filters runslikealpaca Everything Else 1 19th June 2009 10:59 PM
Paging Mr. Pass, Mr. Pass pull my finger please. khundude Pass Labs 2 5th December 2008 04:11 AM
Pass Tharagard A75 vs Pass Aleph 1.2's daly41k Pass Labs 7 18th February 2007 03:10 PM
Amperes of Pass amps & Pass for ESL rick57 Pass Labs 3 4th August 2005 03:28 PM
My opinion on Pass Labs and Mr. Pass (Nelson) himself b_online Pass Labs 11 21st May 2003 12:39 AM
Copyright ©1999-2013 diyAudio
