#691 |
Hi all & off course mr. Nelson Pass
another newbie question, how if i want to make the pass delite using the irfp240 only without using the ixys and semisouth fet. any schematic? thank you regards denis |
#692 |
Page 10 of the DeLite article covers that
“Be who you are and say what you feel because those who mind don't matter and those who matter don't mind.” Dr. Seuss |
#693 |
Note to myself: Never again use fingers to check if there still is voltage left in a capacitor... |
#694 |
The one and only
I think you don't want to lose sight of
2SK82 + Lightbulbs = Fun posted by the notorious smarty-pants Mike Rothacher.
#695 |
thank you guys,
well, i think i need to read everything from the beginning again. it's my new diy try after the dc coupled b1 . sure that i had to read all over again to understand how they work. it's a bit hard for an accountant :-) |
#696 |
hello:
did anyone ever offer a DeLite kit or pc board for the "final" version of this amp? |
#697 |
The one and only
Probably not. It's too simple to justify that much effort.
#698 |
Hello All , I have a little question .
I am just trying a version with the depletion Jfet and the light bulb . Also a little feedback loop resistor from Drain to gate . These are the values : R, light bulb 15 ohm I, 2 amps Vgs, -5,3 volt Vds 30 Volt Vdd 60 volt . Is that ok? or the current is too strong for the D-Jfet ? Thanks |
#699 |
The one and only
Keep it cooled and you should be OK.
#700 |
Hi Mr. Pass and you guys over here
This is my first post in this thread and I have been following diligently with the Delite amp and its various permutations. ;D I have decided to plunge in after listening to Tony Wong's creations and loved the sound that the Delite can give. However, the light bulb I can live without as I prefer to listen in the dark. A 1000W bulb is a leeetle bit too bright for my liking. Glowing tubes like the SV811/572/211/845 I can live with and I have. The Delite CCS is a Godsend! Now, after following Sgr Steffanobillani's CCS circuit on page 61 post #605 to the letter, I have this little problem, I am unable to get half the rail voltage (40V DC) at Q1's drain. Q1 source is 1.8V, Q2 source is 34.7V, Q1 drain is 31.5V. Adjusting R7 doesn't seem to do anything except vary the voltage between R7 and R10 from 34V to 23V. How do I bias Q2? My creation is posted in this forum [url=http://www.xtremeplace.com/yabbse/index.php?topic=72166.msg694442#msg694442]here.[url/] |
| DIY Low Pass and Mid/High Pass (Bass Blocking) Filters | runslikealpaca | Everything Else | 1 | 19th June 2009 10:59 PM |
| Paging Mr. Pass, Mr. Pass pull my finger please. | khundude | Pass Labs | 2 | 5th December 2008 04:11 AM |
| Pass Tharagard A75 vs Pass Aleph 1.2's | daly41k | Pass Labs | 7 | 18th February 2007 03:10 PM |
| Amperes of Pass amps & Pass for ESL | rick57 | Pass Labs | 3 | 4th August 2005 03:28 PM |
| My opinion on Pass Labs and Mr. Pass (Nelson) himself | b_online | Pass Labs | 11 | 21st May 2003 12:39 AM |
