#41 |
Great. I thought N.P. said this thing was 5 bucks and available at Digi-Key...
Well, to him maybe. It's listed a $6.70 or something w/none in stock(non stocked) and a min order of 60! Oh well... I'm deffinatly up for a handfull of those. Thx
“Be who you are and say what you feel because those who mind don't matter and those who matter don't mind.” Dr. Seuss |
#42 |
Just a bump to keep me in the loop...
mE.
"Sometimes obstacles are put in our way to make us slow down so that we can enjoy the journey and appreciate the destination when we eventually get there" |
#44 |
Nelson said at BA that the IXYS thingy was about 6 bucks a pop and one of those non-stock "stock" items at Digikey with a min order of 60 pieces ( about two-three tubes worth). He flat-out recommended a group buy.
#45 | |
not politcally affiliated
I am offering a group buy for these. Offering another solution, you can order them from mouser individually, at a higher costs. The group buy will take about two months from close to get delivery.
Salas Boards 2013 #2 CLICK HERE | F6 Covertible PCB GB Boards Available |DCB1 boards and KITS available PM|SemiSouth R125, R100, R100A Available CLICK HERE |F5TC Boards Sign UP CLICK HERE |
#46 |
Where to find those beautiful light bulb sockets Nelson uses on this amp?
The ones on the photos linked by Steve seem to be the same... I already checked german online stores, the nicest ones I found are those:
Brutalized by bass and terrorized by treble... |
#47 |
Getting "proper" lamps in Europe should not be so difficult, but they may not look so "romantic" like the old style incandescent lamp. For example, this one can be used: OSRAM 64701 300W 230V R7S - Licht-123 -Leuchtmittel - Strahler - LED - Osram - Philips - SLV - Paulmann - Trio - Megaman - Massive Beware that in order to get the needed current, up to ten such lamps may need to be wired in parallel (5-10 actually, depending on the desired current). Also, a funny idea would be to build an amp which would actually look like a small stove. (actually an amp inside a small stove). Or, an amp with a pair of water kettles on top, like this: Amazon.com: Aroma AWK-115S 1-1/2-Liter Hot H20 X-PressWater Kettle: Kitchen & Dining (they will have be filled with a bit of water, which will get warm during operation) ![]() On the other hand, its is known that Nelson uses a lighbulb as a CCS in his tutorial examples. So, we may be looking toward another depletion mode mosfet on top as a CCS. Then, let's revise most of the ZEN series (1-7)...I think that SOZ with the Ixys device would be cool (hot actually)
#48 | |
PM me if interested.
- Fred - |
#49 |
Has anyone considered using a ballast tube instead of a light bulb for the CCS? |
#50 |
Hola Hombres,
Back In the 60's and 70's some chrysler autos used ballast resistors in the 12V primary side of the ignition coil circuit(readily available maybe a source to be checked out ((beefy thing in ceramic and nichrome assy's))... Just a thought.. Dreaming In SC, Elwood
| DIY Low Pass and Mid/High Pass (Bass Blocking) Filters | runslikealpaca | Everything Else | 1 | 19th June 2009 10:59 PM |
| Paging Mr. Pass, Mr. Pass pull my finger please. | khundude | Pass Labs | 2 | 5th December 2008 04:11 AM |
| Pass Tharagard A75 vs Pass Aleph 1.2's | daly41k | Pass Labs | 7 | 18th February 2007 03:10 PM |
| Amperes of Pass amps & Pass for ESL | rick57 | Pass Labs | 3 | 4th August 2005 03:28 PM |
| My opinion on Pass Labs and Mr. Pass (Nelson) himself | b_online | Pass Labs | 11 | 21st May 2003 12:39 AM |
