IXYS depletion MOSFETs: What are they good for? IXYS depletion MOSFETs: What are they good for? - Page 2 - diyAudio
Old 28th October 2009, 02:56 AM   #11
wrenchone is offline wrenchone  United States
wrenchone's Avatar
Let us know when you figure out the name... The use of a depletion mode FET simplifies the design and makes it more tube-like in concept, if not in sound. I prefer to view the Ixys depletion mode fets as pentodes without heaters and extra annoying pins. Treating them as such may prove to be interesting.
Old 28th October 2009, 04:13 AM   #12
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
I think Hiraga did one of those...
Old 28th October 2009, 05:15 AM   #13
wrenchone's Avatar
I nosed around a bit in the forums devoted to Hiraga's works, and haven't seen mention of a transformer coupled amp yet (not that that means a whole lot). The concept is so obvious, I can't believe no one's done it before. The addition of a deplection mode output device adds a touch of innovation, but not a whole lot, Anyway, it's an excuse to dust off the pair of One Electron UBT-1s that have been gathering dust, because this application is made to order for them.
Old 28th October 2009, 10:23 AM   #14
flg is offline flg  United States
flg's Avatar
I suppose the lowish idle current you would want for the typical transformer might contradict the highish idle current you would want for the MOSFET to be in a linear area? Unless maybe a para-feed type topology were used
"It was the perfect high end audio product: Exotic, inefficient, expensive, unavailable, and toxic." N.P.
Old 28th October 2009, 11:25 AM   #15
Ejam is offline Ejam  Australia
Default Hiraga Amp
Hiraga's SE Mosfet amp (called the Nemisis) from memory used a Hitachi lateral mosfet (2SK135) and an output transformer (64 ohm primary winding). The mosfet had 1A of current running through it. So I think the UBT-1 would be well cooked, even fried. Also if you check Bonavolt's website you should find a circuit of the Nemisis there. Hope this helps.
Ejam
Old 28th October 2009, 11:34 AM   #16
Default Wrong Spelling
Sorry, got the spelling wrong, it should be "Nemesis". Jan Didden at Linear Audio has a few words about rebuilding one of these amps. Try http://www.linearaudio.nl/nemesis-1.htm
Old 28th October 2009, 12:22 PM   #17
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
The original output transformer is no longer available, but I have a prototype from another manufacturer on order. As soon as I get it, I will test it in the original Nemesis and with one of these depletion mode MOSFETs. I'll keep you guys posted.
I am currently using the ECF10N16 from Exicon, but the new device should make the circuit even simpler. Maybe even beat Nelson at his own game
jd
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
Old 28th October 2009, 12:42 PM   #18
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
janneman - have you any info about these xformers ?
winding ratio etc ?
edit : I forgot that in original schematic is written 64:8 ohms
any other info , besides that ?
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 28th October 2009, 01:03 PM   #19
Gordy is offline Gordy  United Kingdom
This one perhaps...
" Schematic by Jean Hiraga published in "L'Audiophile" named Némésis. "
2SK135 SE Amp
Old 28th October 2009, 01:24 PM   #20
tubesguy is offline tubesguy  United States
Zeus.
IXYS depletion MOSFETs: What are they good for?Hide this!Advertise here!
2sc3381-GR, Rubycon 410uF photoflash, and IXYS 1kv Depletion mode MOSFETS pabbi1 Swap Meet 3 27th June 2009 03:24 AM
Depletion mode mosfets for 2mA CCS ? mach1 Tubes / Valves 6 29th October 2008 08:50 PM
New Linear MOSFETs from IXYS Kashmire Pass Labs 3 27th April 2007 10:39 AM
n/p Mosfets vs depletion mod mosfets marcello7x Car Audio 6 4th October 2006 05:01 AM
IXYS mosfets ? woody Swap Meet 1 30th August 2003 06:25 AM
Copyright ©1999-2017 diyAudio
