Old 25th January 2012, 08:29 PM   #31
johnm is offline johnm  United Kingdom
johnm's Avatar
Many thanks - much appreciated
- John
Old 26th January 2012, 04:39 PM   #32
KatieandDad's Avatar
Originally Posted by KatieandDad View Post
I'm using 9-0-9 30Va toroid + WOO1 bridge + 4700uF + 2R2 + 4700uF
Someone suggested running B1 at 22V so I'v got a straightforward LM317 reducing the 25V from the CRC down to 22V. But to be perfectly honest it runs silently and perfectly at 25V from my basic PSU.
Nelson's original B1 only used a Wall-Brick and the on-board 15000uF 1R0 15000uF gets rid of any noise.
I wouldn't recommend an SMPS wall brick.
Yes I'm using 9-0-9 as a single 18V supply which is then rectified which gives about 25V after the caps.
UcD400 aux supply options PWatts Class D 6 7th July 2011 04:39 PM
UCD Supply ST Transformer Options Juke425 Class D 0 28th July 2008 10:14 PM
Power supply options.. bigger trafo with less caps or medium trafo with heavy caps? rhythmdiy Chip Amps 9 23rd October 2007 12:30 AM
Amp6 Power Supply Options Davet Class D 5 20th May 2006 11:37 AM
Gainclone power supply options/questions trespasser_guy Chip Amps 3 28th April 2003 02:52 AM
Page generated in 0.05970 seconds (66.41% PHP - 33.59% MySQL) with 11 queries
