Old 22nd October 2009, 05:45 PM   #11
I'm using a PSREG power supply board from Welborne Labs, set to 18v with Elna Cerafine caps
Been there, Heard that, Forgot what I was listening to!
Old 23rd October 2009, 12:32 AM   #12
Beftus is offline Beftus  Netherlands
Beftus's Avatar
Originally Posted by dubai2000 View Post
That looks smart - thanks a lot for the info .
It certainly does! Combine it with a tiny toroid and you're good to go.
Old 24th October 2009, 05:09 AM   #13
Has anyone tried one of these? Energizer Universal Mega Cell Battery Pack
Woot : Energizer Universal Mega Cell Battery Pack
Old 6th November 2009, 05:44 PM   #14
Beftus's Avatar
Originally Posted by R-K Rønningstad View Post
I bugh the nice and small Velleman K1823 for my B1. It has a LM317, rectifier diodes, and a cap. And a pot to adjust the output voltage.
I replaced the standard 1N4004 (or whatever it was) with some better ones. It only has 1000 uF, but the B1 itself has some capacity, and you can always add some external bulk as well.
At least it is a USD10 or so starting point.
Rolv-karsten
I bought one today too. What did you replace the standard diodes with? I plan to ditch the supplied Jamicon caps and replace them with Panasonics. Mine came with a 2200µF 'lytic, not 1000µF.
Old 6th November 2009, 07:01 PM   #15
Formerly Thanh1973
If it is not too expensive give it a go. It defnitely has potential
Old 2nd December 2009, 01:38 AM   #16
LucasAdamson's Avatar
I am looking to power up my B1 now as it's all soldered up.
The board not a Pass Labs, but a clone. It has a shared section consisting of 2x 15,000uF caps, a diode, led and resistors before the gain stages, as in the Pass schematic. Isn't this stuff the tail end of a power supply?
Could I simply use a small toroidal transformer and a MUR860 diode rectifier I have spare to supply 18v DC to the unit? Would that be sensible?
Lucas
Old 2nd December 2009, 12:17 PM   #17
Beftus's Avatar
No, I don't think that would a good idea. Feed it from a dedicated PSU which can be either:
-2x 9 volt batteries in series
-a switch mode PSU (think laptop PSU)
-a cheap wall wart
-a diy PSU (rectifiers, capacitance, regulation)
Old 2nd December 2009, 12:41 PM   #18
a 15Vac transformer will give about 22Vdc. This can power your B1, if you increase R1 (the RC of the PSU output filter).
regards Andrew T.
Old 2nd December 2009, 03:03 PM   #19
i have a sigma11 lying around that i was planning on using for my B1: The σ11 Regulated Power Supply.
Old 2nd December 2009, 03:13 PM   #20
-a cheap wall wart
Can you explain why what I suggested is not a DIY PSU and why it isn't a good idea? This is how my gainclone is powered, with much smaller caps.
Lucas
UcD400 aux supply options PWatts Class D 6 7th July 2011 05:39 PM
UCD Supply ST Transformer Options Juke425 Class D 0 28th July 2008 11:14 PM
Power supply options.. bigger trafo with less caps or medium trafo with heavy caps? rhythmdiy Chip Amps 9 23rd October 2007 01:30 AM
Amp6 Power Supply Options Davet Class D 5 20th May 2006 12:37 PM
Gainclone power supply options/questions trespasser_guy Chip Amps 3 28th April 2003 03:52 AM
Page generated in 0.10631 seconds (75.46% PHP - 24.54% MySQL) with 11 queries
