#11 |
Paper mache horn fabricator
I meant, the Ciss is ten time higher than what we normally see in a mosfet. This makes for poor treble, if I recall correctly.
I enjoy audio so much that I constructed a web site. I share my ideas at: www.inlowsound.com |
#12 |
And for more driving current from the previous stage!
Sam |
#13 |
I din't know, what you mean with the keyword "Normal MOSFETs"
as I compare the values CISS COSS and CRSS I read in the datasheets (by VGS=0V, VDS=20V and f=1MHz) follow pF values http://ixdev.ixys.com/DataSheet/DS10...10N20L2%29.pdf http://www.irf.com/product-info/data...ta/irf540n.pdf http://www.datasheetcatalog.org/data...onics/9387.pdf IRF540-D Datasheet pdf - TMOS E-FET Energie Fangen Effekt-Transistor N-Führung Verbesserung-Modus Silikon-Gatter auf - ON Semiconductor or http://www.datasheetcatalog.org/data...r/IRF540-D.PDF 2SK134 datasheet pdf datenblatt - Hitachi Semiconductor - LOW FREQUENCY POWER AMPLIFIER ::: ALLDATASHEET ::: http://documentation.renesas.com/eng..._2sk2220ds.pdf http://www.semelab.com/pdf/magnatec/BUZ900P.pdf 1) IXYS IXTX110N20L2: 23/2160/320 (lowest CISS what I have ever see regarded the other parameters, for very low driver charge current) 2a) IRF IRF540: 1960/250/40 (VGS = 0V, VDS = 25V) 2b) ST IRF540: 870/125/250 (VGS = 0V, VDS = 25V) 2c) ON IRF540 : 1460/390/320 3) Hitachi 2SK134: 600/350/10 (but VGS 5V/VDS 10V) 4) Renesas 2SK2221: 600/800/8 (also VGS 5V/VDS 10V) 5) Semelab BUZ900 500/300/10 (VGS not mentioned, VDS 10V) |
#14 | |
#15 |
Smaller resistors are necessary to deal with the higher C values so as not to cause a reduction in high frequency response. More importantly might be the non-linear C increase as the device D-S voltage lowers. But in the case of the IXTK110N20L2 that happens well bellow 5V. Uniquely good compared to MOSFETs we typically use.
“Be who you are and say what you feel because those who mind don't matter and those who matter don't mind.” Dr. Seuss |
#16 |
Formerly Thanh1973
what about this one http://ixdev.ixys.com/DataSheet/9ad7...3a9ba842d9.pdf
Or what about this one http://ixdev.ixys.com/DataSheet/0792...410e7fb8a2.pdf
"No, this sucker's electrical, but I need a nuclear reaction to generate the 1.21 gigawatts of electricity I need." Last edited by Melon Head; 25th October 2009 at 09:13 PM. |
#17 |
Yes, you are right, that was a mistake from me. Amazingly is, that also the use for linear amplifier was recommended in the datasheet from IXYS. So only at one stage amplifiers such "ZEN", "First Watt" and "Circlotron" this MOSFET work without trouble, because in this topologies the behaivour of capacity is like low pass filter
| 807 E-Linear | Fuling | Tubes / Valves | 51 | 5th April 2011 01:27 AM |
| linear pot | sakis | Solid State | 4 | 9th August 2008 01:34 PM |
| Linear PS help | ashley_kitty | Power Supplies | 2 | 16th May 2007 12:00 AM |
| Need help with linear PS | tonyptony | Power Supplies | 33 | 14th April 2006 09:37 AM |
| Help with Linear PSU | meta | Parts | 26 | 19th March 2003 03:56 PM |
| Page generated in 0.09285 seconds (82.87% PHP - 17.13% MySQL) with 10 queries |
