Old 15th October 2009, 05:35 PM   #1
tiefbassuebertr's Avatar
Default Better MC Pre-Pre solution for low internal coil resistance- not only for Pearl phono
The presently MC prepre of the Pearl phono stage (configured as high input impedance common emitter line stage with input at gate of the j-FET) is the ideal choice for MC cartridges with internal coil resistance above 100 ohms. If I have a internal coil resistance arround 15 until 40 ohms (like some models of Lyra and Audio Technica) I get better results (more tight and clear so as more sonic dymanics) with line stages in common base topology like Hiragas prepre, see
Hiraga MC Preamp
or the Mark Levinson JC1 (see pdf schematic)
what could be the reason for this?
Old 15th October 2009, 09:54 PM   #2
Holger Barske's Avatar
Disagreed. Even with low impedance sources, the Ono/XP-15 is one of the quietest phono preamps I have had my hands on.
Best regards: Holger
www.holgerbarske.com
Old 15th October 2009, 10:19 PM   #3
analog_sa's Avatar
The Hiraga circuit is a great sounding classic. Not so sure about the JC1 with the 1000uF at input.
If noise is not an issue i would take a single resistor loaded common cathode fet (or even better - a triode) instead of the Pearl arrangement.
Old 16th October 2009, 06:02 PM   #4
You haven’t understand my question.
Additional I don’t know about the phono preamp “ONO/XP-15”
I know only the models
- “Aleph ONO”
- “X-ONO” (successor Aleph ONO)
- “XP-15” (currently available and successor for “X-ONO”)
Maybe you mean one of this models.
The Pearl Phono stage (not a commercial product)
http://www.passdiy.com/pdf/pearlphono.pdf
use as MC prepre a line stage in common emitter resp. source topology, i. e., a voltage controlled input. For me it is definitely clear, that MC prepre versions, which use a common base topology, that means current control input (unfortunately, very few commercial models), give better sonic quality by MC cartridges with low internal coil impedance (but I don’t know, why; and a possibility for configuration to both topologies it would be very helpful).
Because I haven’t schematic of all three mentioned models, I will not rule out, that one of the above Pass models use a prepre topology which use a common base topology (because one of the earlier preamp model of master developer Nelson Pass uses also a common base respective gate topology – see PDF file at bottom). Perhaps this is the reason of your statement.
The type number “ONO/XP-15” is total unknown for me – please send me a weblink about this, if it should really exist.
Old 16th October 2009, 06:04 PM   #5
PDF Threshold SL-10
Old 17th October 2009, 11:34 AM   #6
use as MC prepre a line stage in common emitter resp. source topology...
The Pearl is intended to be used with MM or high ouput MC cartridges, not with classical MC cartridges. Despite from the fact that the input stage is far from optimal for MCs (you are right on that one), overall gain is a little low for MCs.
Automotive relays and internal resistance? pjpoes Everything Else 2 9th February 2007 05:18 PM
811A tube internal resistance ? Zoran Tubes / Valves 38 11th May 2004 08:33 AM
Pearl - internal wires and grounding question Boban Pass Labs 3 2nd March 2003 04:03 PM
A question on v coil resistance (NOT impedance) Fossil Multi-Way 3 29th August 2002 05:27 AM
Temperature effect on voice coil resistance AudioFreak Multi-Way 5 2nd January 2002 02:14 AM
Page generated in 0.10766 seconds (73.92% PHP - 26.08% MySQL) with 11 queries
