#51 |
I am going to build my F5, and I want to find that sweet spot!
Has anyone built (or looked at) Richard Crawford's "1 PPM IM Distortion Analyzer" (AudioXpress, March 2004)? I'm looking for something that won't break the bank, but something I can use for a while. The total cost was quoted at $150 (in 2004) including the board which is still available from AX, but excluding knobs, connectors, etc (and you use your DMM for the display). It's claimed to be able to measure IM to 0.0001%. It measures the difference frequency at ~800 Hz and uses various test tones: 1) 19.2 kHz & 20 kHz for 2nd order harmonic, 2) 9.6 kHz & 20 kHz for 3rd order, and 3) 9.6 kHz, 10.4 kHz & 20 kHz (all at same amplitude) for 2nd plus 3rd order. Unfortunately I'm really new at this and don't always completely understand everything I'm reading. Also, I don't know if $150 is reasonable for what this does. I hate that! Any help or advise would be very much appreciated! Thanks, Looney |
#52 |
Fore biasing my AB amps I have always used my ears, which seem to work fine
Small changes to one channel at a time Its easy to detect which channel is better I have found it usually ends at a point where DC on output is most stable, maybe not at the lowest value, but where its most steady And I like heatsink on both channels to be equally hot Needless to say I do it while playing music I could imagine it might be a dangerous approach with classA
#53 |
I would like to second Itsmee's motion for a list or table of approximate "sweet spot" operating points for popular parts. Especially 2sk170,2sj74 fets, typical "audio" bjts (ztx450,550; bc550,560 etc). Also, some sort of mention regarding the range of deviation.
I did a little reverse engineering and I would like to see if I'm on the right track; I went back and looked at the F5 and F4 schematics. I am guessing the jfets are optimal around Ids=6-8mA and Vds ~20v (Since I'm sure Mr. Pass would have gone through the trouble to find the "sweet spot" for his own products!) Is that about right for the "bl" parts? |
#54 |
Well, for the JFETs you might read the JFET BOZ thread. They play with the Supply Voltage alot looking for it...
Jfet BOZ
“Be who you are and say what you feel because those who mind don't matter and those who matter don't mind.” Dr. Seuss |
#55 | |
Great idea of using one channel as a reference while tweeking the other. I will definitely try it. Looney |
| Better than the current sweet spot of value?? | rick57 | Full Range | 4 | 16th June 2005 07:23 PM |
| ESL imaging, soundstage, sweet spot ??? | michaelpage26 | Planars & Exotics | 6 | 6th December 2004 08:42 PM |
| "Sweet spot" | Flavius | Multi-Way | 12 | 26th June 2003 02:27 AM |
| Aleph Temperature Sweet Spot | macka | Pass Labs | 12 | 21st March 2002 10:39 AM |
| Page generated in 0.08956 seconds (78.69% PHP - 21.31% MySQL) with 10 queries |
