Old 31st October 2009, 05:44 PM   #21
Sheldon is offline Sheldon  United States
I think the jumpers are there if you want to do some programming. I don't believe they are used for normal operation. I'd look for a simple error somewhere (that's usually what I end up finding in my projects). LED's oriented correctly?
Sheldon
Old 31st October 2009, 05:56 PM   #22
I guess the leds are OK. The guy I bought it from used to have it in working order... (He is an electronics engineer but he is not giving me support I'm afraid...). Actually I can think of nothing else to check. Maybe it is something in the firmware menu?
Old 31st October 2009, 08:57 PM   #23
Removed the input selector just to be sure... Still no sound.
Going to remove the Aleph's next and see if it works as a passive attenuator...
Old 31st October 2009, 09:52 PM   #24
Using it as a passive attenuator. Have sound on one channel only when I turn the volume way up... Going to check everything tomorrow.
Old 31st October 2009, 11:41 PM   #25
Cobra2 is offline Cobra2  Norway
DIY !
Cobra2's Avatar
Send a message via Skype™ to Cobra2
Are the LED's mounted with "flat-side" out? They should blink.
And, I think you need to ground the -(negative) if you use single-ended input?
Arne K
Ars longa, vita brevis
Old 1st November 2009, 06:18 AM   #26
I'm afraid I don't know what you mean with "flat side out". Leds are not blinking in any way. (I even turned out the lights to check if they were burning very low...)
The software gives the possibility to use the volume board single ended. This option is switched on so there is no need to connect - to ground.
Old 1st November 2009, 07:30 AM   #27
DIY !
Cobra2's Avatar
Flat side = cathode, facing out toward the board-edge
Arne K
Old 1st November 2009, 10:28 AM   #28
Looks like you are right Arne! But would the wrong position of the leds influence the functioning of the volume board?
Jan
Old 1st November 2009, 11:16 AM   #29
Put the led's in the right position. On led blinking and one led blinking only as i turn up or down the volume.
Old 1st November 2009, 11:48 AM   #30
DIY !
Cobra2's Avatar
One problem fixed..., and one to go?
Arne K
FS: 6-channel volume--discrete, balanced (APOX) tiroth Swap Meet 8 8th March 2005 03:42 PM
APOX Volume and Input select for sale Coulomb Swap Meet 4 15th April 2004 01:21 PM
Another APOX volume control project tiroth Solid State 17 30th March 2004 08:25 PM
APOX passive volume grounding tiroth Solid State 0 27th February 2004 05:53 PM
Tube Preamp for Apox Volume Control Rarkov Tubes / Valves 19 1st December 2003 09:51 PM
Page generated in 0.09358 seconds (79.19% PHP - 20.81% MySQL) with 11 queries
