Hello,
in NP's new preamps he uses different kind of coupling caps with a white color. In his older preamps (e.g. X0) Panasonic with an orange color were used. Has anyone an idea which type the new caps are? Thanks for help Ralph |
#2 |
Official Court Jester
probably Papa knows
my Papa is smarter than your Nelson ! tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery
#3 |
The caps we use are Wimas, Elna, Panasonic and Vishay. The XP10 and XP20 are DC coupled so be careful with your sources.
#4 |
The one and only
#5 |
Hello,
as far as I know both preamps have an integrated variable resistor from Maxim as a volume regulator. This device has a single supply and you need two coupling caps there for every signal path. Regards Ralph |
#6 |
They don't in the preamps we build. The 1802 is single supply. the 1882 is ran on +- 6.8 Volt supply. A wonderful part the 1882 has no opamps and great specs.
You will see they spec parts worse case not best as most companies do. |
#7 |
But it will only work with 6,8V (I thougt 2V but it seems to be maximum iss VCC). So Gain must be reduced in Input...
![]() Does it make sense? Best regards Felix Last edited by Kamel; 10th October 2009 at 10:52 PM. |
#8 |
The one and only
That limitation only exists in the application notes, and even
then I wouldn't consider it a serious issue. Does your source voltage exceed that? |
#9 |
Perhaps my Ono. It's maximum Output is 20V rms...
Best regards Felix |
#10 | |
![]() what's gain of Ono , and what's signal level feeding it ? then calculate whats real output
| Xp10 | HiFi Si | Pass Labs | 8 | 29th September 2009 10:48 PM |
| no coupling caps | ray bronk | Tubes / Valves | 2 | 20th May 2008 08:10 AM |
| Coupling caps. | Trebla | Class D | 5 | 1st March 2006 10:12 PM |
| Pre-amp coupling caps | Bill Fitzpatrick | Parts | 15 | 4th March 2005 12:54 PM |
| coupling caps | el capitan83 | Tubes / Valves | 10 | 17th December 2004 05:25 PM |
| Page generated in 0.10493 seconds (82.74% PHP - 17.26% MySQL) with 10 queries |
