Old 6th October 2009, 09:02 PM   #1
Default F5 wiring
I'm building my first amp and, as the title obviously indicates, I'm going to try an F5. I'm not going to use any pre-made pcb's, and I'm just learning electronics, so I am looking to have someone fact check this layout. Yes, it's Mr. Pass' exact layout, but it's hard enough for me to reverse engineer this with my skill so it makes it a little easier for me to visualize. Anyway, enough excuses, please review this and let me know if I connected everything like my picture, would it be ok?
Old 6th October 2009, 10:07 PM   #2
R-K Rønningstad's Avatar
The connections drawn seems correct. But only the positive part is drawn.
You may have good reasons not to get a PCB from e.g. Peter Daniel. I will however strongly suggest you get PCBs for this project. See F5 pcb group buy... for details. This makes errors much less likely.
Regds
R-K
Old 6th October 2009, 10:26 PM   #3
Thank you for your response. Yes, I figured I would try to make sure I understood V+ for one channel and if I could at least get that right, I would finish out the whole channel. I'm also going to try and separate the power supply.
This is all a big learning experience as much as it is building a cool amp that I can use when I'm done. I'm really a learn by doing kind of guy. I can read something over and over, but until I blow it up, er, I mean, get it to work, it doesn't always sink in. I am also looking at doing something eclectic with the "case" and "pcb" so pre-fabbed pcb's don't fit the bill.
Old 6th October 2009, 11:46 PM   #4
The one and only
Nelson Pass's Avatar
I like to lay out boards just like the schematic. Works
every time.
Old 7th October 2009, 03:07 AM   #5
You'll learn much more doing it yourself. PCB's are nice of course, but it ain't the same. More power to you!
Vince Harris
Old 7th October 2009, 03:15 AM   #6
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Sure you can do it, shouldn't be a problem: http://www.diyaudio.com/forums/pass-labs/3840-beaty-p2p-wiring-post34126.html
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 7th October 2009, 03:55 AM   #7
tinitus is offline tinitus  Europe
I have both the PeteDaniel boards, and Cvillers
Both very nice
But I still like to play with this
Just be aware of errors
They seem to happen every time I make changes
Would be fun to try and make double sided boards, but Im certain I would choose hardwire on thin Pertinax plate
But playing with the board layout still seems to give me some idea about how to hardwire it
Old 7th October 2009, 08:49 AM   #8
Thank you all for the information and kind words. I'll be sure to update as I progress with the project.
Old 8th October 2009, 12:40 AM   #9
Default full channel
Well, here goes the full channel. I don't think I screwed anything up moving it all around, but there's always a chance. Would there be a problem if I actually terminated all the connectors as diagrammed in the middle there? I was trying to sift through the thousands of posts for what should and shouldn't be near each other, but most everything that came up was PS related.
I was even thinking of pulling out all of the center R1-R2, R5-R10, Q1-Q2 onto another board entirely. What would be the pros & cons of that?
Old 8th October 2009, 04:57 AM   #10
Hi
I think Nelson has stated that layout doesnt make significant difference
I think it was also stated that its important not to have input signal close to supply rails
And THAT you seem to have
But your layout looks good
I may try to do layout that way
Wiring this as SUT pjanda1 Analog Line Level 3 14th May 2008 02:58 PM
Focusing on wiring cable for gainclone!!!Share ur experience in wiring cable.... thomgun_lc Chip Amps 38 31st August 2005 03:46 PM
I'm wiring my 4 channel 8 parallel LM4780 boards... check my wiring :) Audiophilenoob Chip Amps 9 16th August 2005 05:37 AM
amp's inner wiring rnzr Solid State 2 15th April 2005 02:51 PM
Bi-wiring?? george a Multi-Way 4 3rd June 2003 11:42 PM
Page generated in 0.09573 seconds (82.54% PHP - 17.46% MySQL) with 11 queries
