Semisouth JFET's: What are they good for? - Page 11 - diyAudio
Old 18th October 2009, 02:28 PM   #101
alexberg's Avatar
Originally Posted by Magura View Post
Hey, since you're the "push 'em over the edge" expert here.
How would you go about soldering a device that gets so hot?
I did some playing around with pushing devices real hard, back then, the only solution I found, was to crimp instead of solder.
Magura
EDIT: And you might as well spill the beans. How do we get that plastic casing off, without damaging the fet?
It have been done before
Look at the attachment... please notice publicaton date
Take care
Old 18th October 2009, 02:40 PM   #102
Paper mache horn fabricator
carpenter's Avatar
Choky, you're bad....
The rest of you guys are scaring me....
I enjoy audio so much that I constructed a web site. I share my ideas at: www.inlowsound.com
Old 18th October 2009, 03:23 PM   #103
flg is offline flg  United States
flg's Avatar
Maybe the temp fluctuation could be handled, by adding some thermal mass?
Magura
Yes, I agree. I was working with bare die mounted to Kapton film only at the die pads. We would typically have several times the mass in copper soldered to the back of the die in a mounted leadframe situation.
BTW, die are typically soldered (Die Bonded) using a "silver solder" type paste that goes liquidous at about 450C.
"It was the perfect high end audio product: Exotic, inefficient, expensive, unavailable, and toxic." N.P.
Old 18th October 2009, 03:30 PM   #104
Magura is offline Magura  Denmark
Magura's Avatar
Hmm, so the magic number is 175.
I see a cube filled with oil in my future
I have been working with high temp adhesives in another project recently, so bonding a JFET to a piece of carbon, and dumping it in such a cube, should be an interesting experiment.
Do you know if the phase change of the fluoinert is 100% reversible, or do I have to consider loss?
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 18th October 2009, 03:43 PM   #105
flg's Avatar
If by "100% reversible" you mean actuall loss of material? My set-up had a cooling unit that kept the fluid a 65C and a condesing coil setup at the top to cool and reclaim all the gasous vapor. The unit would typically be almost sealed but when we open the lid we would incure some loss. flourinert was $350-550 a gallon then (1994)
BTW, if you actually burn or epose florinert to flame it will produce a fatally poison gas
Old 13th December 2009, 12:43 AM   #106
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
Hey, anyone got any ideas yet?
I have a dozen of these critters in the mail. I will probably try these with the BA-1 variant, it seems the most flexible.
Any advice on trying to match these things?
Old 13th December 2009, 12:51 AM   #107
carpenter's Avatar
Plug them into a wall outlet and match by how much they dim the lights?
Old 13th December 2009, 01:01 AM   #108
Tea-Bag's Avatar
Yep, my HP bench supply can't do a 1000V. Just wondering if this needs any special attention compared to older NP matching articles. I mean VGS @ 24v at 1A? Just trying to avoid mounting them to a heatsink to match.
Old 13th December 2009, 01:18 AM   #109
carpenter's Avatar
I would think Nelson's matching technique would work fine...
You could always hook them up to a heat sink and match them to the wattage draw they'll encounter in the actual circuit.
Old 13th December 2009, 08:59 AM   #110
Magura's Avatar
Did you get the 125 or the 120 variant ?
I have been told, that the 120 variant is within tighter tolerances withing each batch, thus easier to get good matches.
Magura
SemiSouth SiC Power JFETs RocketScientist Solid State 105 19th February 2012 09:02 PM
Semisouth JFET GB Magura Group Buys 418 14th December 2010 08:49 AM
Can I replace BF245C JFET with J201 JFET? bigmike216 Parts 2 7th December 2005 07:50 AM
Need good current sink JFET or MOSFET? rlaury Tubes / Valves 7 22nd November 2005 07:14 AM
Copyright 1999-2017 diyAudio
