Old 2nd October 2009, 08:16 PM   #1
Michele is offline Michele  Italy
Default B&W 800d......Pass XA200.5 or X600.5?
2 questions:
Which is the best choise?
What about XA 200.5 power supply?
Best regards
Michele
Old 2nd October 2009, 08:35 PM   #2
The one and only
Nelson Pass's Avatar
Both should be fine - the decision depends more on your
preferences.
What about the power supply?
Old 2nd October 2009, 08:43 PM   #3
Formerly Thanh1973
Melon Head's Avatar
Without actually hearing them I would probably go with xa200.5
"No, this sucker's electrical, but I need a nuclear reaction to generate the 1.21 gigawatts of electricity I need."
Old 2nd October 2009, 08:45 PM   #4
preferences.
Thank you Nelson.
XA 200.5 transformers and capacitors are the same i can find in the x1000.5, aren't them?
Michele
Old 2nd October 2009, 09:04 PM   #5
Formerly Thanh1973
Melon Head's Avatar
Sorry to go slightly off topic. But it may prove to be helpful.
Hi Nelson
Is their any difference between the circuits of the XA amps and the X amps,
or is it just to do with the biasing.
My understanding is, they are similar to a supersymetric Aleph 0, with 2 gain stages instead of 3 which the original Aleph 0 had
Old 3rd October 2009, 04:38 AM   #6
The one and only
As I recall we use one for each rail to get the voltage.
Old 4th October 2009, 05:11 PM   #7
preferences.
The choice is extended to the XA160.5
Old 4th October 2009, 08:54 PM   #8
Formerly Thanh1973
Melon Head's Avatar
800d specs
Sensitivity: 90dB/W/m
Impedance: 8 Ohms nominal (3.1 Ohms minimum)
All I will add here is, GO FOR IT.
XA160.5 or XA200.5 will do the job. If you can afford it go with the XA200.5.
At least then you won't have to wonder about whether the XA200.5 would sound even better.
Old 9th November 2009, 07:41 AM   #9
Wich are differences between xa 160.5 and 200.5? (only power output?)
Old 9th November 2009, 02:08 PM   #10
The one and only
Power output, heat sinking, supply capacitance. They use
different taps off the same type of transformer.
XA 100.5 and B&W 800d Michele Pass Labs 4 4th April 2009 12:55 PM
X600 -x600.5 bebo60 Pass Labs 2 27th January 2009 11:01 AM
Help! Building an amplifier to run B&W 800D harrisni Solid State 9 16th September 2006 11:45 AM
Pass XA200 Apogee Pass Labs 7 3rd July 2002 10:39 PM
Pass Labs XA200 amplifier GRollins Pass Labs 15 27th March 2002 08:23 PM
Page generated in 0.08993 seconds (83.44% PHP - 16.56% MySQL) with 10 queries
