Old 1st October 2009, 09:42 PM   #1
Default VoltageDAC with B1 output buffer
Here's a description of my latest DIY project. A voltage DAC (CS4398) with 4 B1 output buffers (balanced).
Nelson: Thank you very much for this incredible little buffer!
Old 4th October 2009, 01:42 AM   #2
The one and only
Nelson Pass's Avatar
That's very cool.
Old 17th December 2009, 09:15 AM   #3
Default Coupling capacitor
I have now made 2 variations of this DAC. I have attached the schematics of one single channel B1 buffer that I use.
The DAC's built are equal down to C9, the coupling capacitor.
Version 1 have 3 cap's in parallell: 100uF electrolytic || 1.1uF Solen PA (metallized polypropylene) || Vishay MKP 1837
Version 2 have 2 cap's in parallell: 1.5uF unknown film cap || Vishay MKP 1837
The sound difference was bigger than expected. I have grown used to version 1. Version 2 were much more forward, the bass was harder and there was less space around the instruments and voices.
All of these film-caps were intentionally bought for passive crossover use. I have never really read any much about capacitor choice in active electronics, so my question here is: Could anyone point me in a direction here?
Old 17th December 2009, 06:37 PM   #4
The one and only
Why do you need the input coupling cap? Is there DC at the
output of the DAC?
Nevermind - I see on your previous schematic.
Old 17th December 2009, 06:44 PM   #5
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
why you need input caps ?
just kill gnd reference for input gates , then place caps on buffer output
well - I suppose that's matter of preference , and type of caps you prefer
edit - I have impression that cap on buffer output is somewhat less critical than cap in input
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
Old 17th December 2009, 06:54 PM   #6
What i prefer? Don't know....
With regards to passive crossover cap's I have found this page helpful: Humble Homemade Hifi
But I have not found any helpful pages with regards to cap's in active electronics. Have you?
Old 17th December 2009, 06:54 PM   #7
Pano is offline Pano  United States
Pano's Avatar
The outputs of the DAC sit at about 2.5V, so you need to take that into account. Blocking caps make it easy.
But maybe there is some way to bias the buffer so that it deosn't care about the offset.
I know how to do that with an opamp, but not the B1.
Take the Speaker Voltage Test!
Old 17th December 2009, 07:04 PM   #8
Zen Mod's Avatar
as I said - just delete gate gnd resistors
in that case - made lowpass filter differentially on input , or blahlah on output .
without gate gnd resistors , each upper jfet will float up and sit where it feel comfortably
and - yeah - if you are lacking some drive from DAC , instead of double B1 - make Jfet BOSOZ , with all XCCSwhatever suffixes and prefixes ..... , and make it SUSY , what else ........
there are plenty of options .....
Old 18th December 2009, 03:06 PM   #9
Hi Zen Mod.
I'm afraid I don't follow you. My incompetence level have been reached...
I have ordered some Wima MKP10 for comparison. Any other brands I should try? Subjective opinions appreciated.
Old 18th December 2009, 04:57 PM   #10
R-K Rønningstad's Avatar
output of the DAC?
Isn't it so that these DACs run off +5 V (and GND), hence each output is more or less midway between. (2.6 V is almost midway....) But as they have differential outputs (Aout+ and Aout-) all will be hunky dory. Or maybe I should have read the rest of the replies before writing... But I had this cup of damn good coffee in front of me and wanted to type something...
current buffer for cd output maxpou Digital Source 0 14th February 2008 04:14 PM
PGA2310 output buffer? Freddie Solid State 26 13th February 2008 10:09 PM
Berning output buffer Bill*B Tubes / Valves 10 16th October 2005 03:12 AM
output buffer for GC question jsteigs Chip Amps 5 24th March 2005 11:06 AM
buffer with balanced output udip Solid State 22 23rd February 2005 06:53 AM
Copyright ©1999-2013 diyAudio
