Old 29th September 2009, 04:38 AM   #1
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
Default SIMPLE Aleph Pre-amp,
I haven't been around much, been lurking around still reading lots still, but haven't been keeping up with all the pass projects.
My goal, is to find a simple, Pre-Amp for my aleph mini's simple is key so i can still achieve CLEAN sound, but something louder than the Passive pot im using.
I;m running the Mini smd alephs x 4 in se mode ( rca single ended ) 2 amplifiers per speaker, ( one for tweeter one for mid bass )
I am currently working on new cabinets to house my new Ribbon Tweeters ( thanks Planet10 ) and my davis 6.5" efficient drivers.
I only have one source, my fave cd player.
So, ideas schematics pictures are all welcome.
J'
Old 29th September 2009, 02:41 PM   #2
DougL is online now DougL  United States
If you plug the CD directly into your power amp is it loud enough? If so, a B1 would help.
If not, I defer the question.
HTH
Doug
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
Old 29th September 2009, 04:06 PM   #3
Gordy is offline Gordy  United Kingdom
HTH
Doug
If your cd player has enough output you may not even need a B1 (/ buffer). I would simply try a 5K potentiometer first.
Old 30th September 2009, 12:26 AM   #4
Banned
Right now i'm using a passive pot for the volume, i do need more maybe 1.5 time gain.
Old 30th September 2009, 12:29 AM   #5
njepitt is offline njepitt  United Kingdom
If you think the B1 is not sufficient, then you might want to take a look at this thread:
BF862 Preamp
It's high on my list of things I want to make soon....
Cheers
Nigel
Old 30th September 2009, 12:30 AM   #6
Our posts crossed... The preamp in the link I posted has a gain of 2, if I recall correctly.
Nigel
Old 30th September 2009, 07:44 AM   #7
Would it be possible to reduce the feedback of your Aleph's?
A simple mod if you enjoy your setup.
Old 30th September 2009, 05:45 PM   #8
juma is offline juma  Serbia
juma's Avatar
BF862 Preamp
Cheers
Nigel
In the meantime, schematic changed:
http://www.diyaudio.com/forums/pass-labs/146310-bf862-preamp-post1938342.html
Old 30th September 2009, 10:03 PM   #9
I suggested removing the passive pot. It may be loading down the CD output. If its loud enough direct connected, a buffer would help, by allowing a higher value pot without loosing HF response or volume.
Try it and let us know.
Doug
Old 30th September 2009, 11:41 PM   #10
Banned
Doug
I tried that long time ago, It defiantly needs more gain,
Simple, SIMPLE Digital volume control -_nando-_ Digital Source 5 21st December 2006 01:20 PM
A simple question for the Aleph 3 owners JEKYLL Pass Labs 6 24th May 2004 07:59 PM
Simple answer required for a simple question... rabbitz Multi-Way 4 31st August 2003 10:05 AM
Simple Aleph 2 transformer question BrianGT Pass Labs 14 7th April 2002 10:27 PM
Aleph P 1.7 more simple in progress Miles Teg Pass Labs 0 28th September 2001 08:30 PM
Page generated in 0.09423 seconds (81.92% PHP - 18.08% MySQL) with 11 queries
