FirstWatt J2
FirstWatt J2
Old 21st September 2009, 08:41 PM   #51
Melon Head is offline Melon Head  Australia
Banned
If these are going to be matched, I would like 8 (ie 4 per channel).
It would be nice if you labelled them with the values. A bit of masking tape will do.
I just need the matching for equal heat dissipation, so they just need to be matched in pairs.
Old 21st September 2009, 08:52 PM   #52
mos57 is offline mos57  Italy
mos57's Avatar
At this moment, please you must follow the thread opened by Magura in Group Buy.
Best regards, Francesco
Old 21st September 2009, 08:55 PM   #53
Banned
Thanks for the info
Old 22nd September 2009, 06:25 AM   #54
relder is offline relder  United States
relder's Avatar
Send a message via Yahoo to relder
Originally Posted by Blues View Post
my first thread in years and just over a weekend and it's already 5 pages...
Morten, I'm interested in your GB the jfets being TO-247s...
Mr. Pass, are the Lovoltechs even an option for the "other" output jfet (CCS)? Might be useful to some who have a stash of those...and cheaper.
The upper FET would appear to have to dissipate as much power as the lower FET, so no dice with the tiny Lovoltech. Using a MOSFET as a cost saving option up there is more realistic.
Old 22nd September 2009, 08:11 AM   #55
MRupp is offline MRupp  Germany
MRupp's Avatar
I was thinking along the same lines. The Lovoltechs are depletion mode devices and the Semisouth are enhancement devices, so just with a bipolar supply there is no headroom for biasing the Lovoltechs. However, an extra voltage source for the input stage of a few Volts and cascaded under the negative supply voltage should work?
The Lovoltech need to be cascoded, same as in the F3 so that takes care of dissipation. Since the Mu follower should be there to cancel distortion, I presume upper and lower device should be the same. The one caveat is that the (Lovoltech + Mosfet) cascode already removes a lot of distortion so it is not clear what effect the mu follower would still have.
My two cents ...
Martin Rupp
Old 23rd September 2009, 01:46 PM   #56
sekess is offline sekess  United States
Default Power Supply
Quote from the owner's manual:
"On the front panel there are two blue LED lights, one for each channel, indicating regulated power to the channel."
Does this mean that the J2 will be getting a regulated power supply instead of the unregulated First Watt power supplies in the previous offerings?
Steve
Old 23rd September 2009, 08:07 PM   #57
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
FirstWatt J2
No, it means that that this section of the manual was cut
and pasted from an F3 manual.
Old 23rd September 2009, 08:12 PM   #58
DougL is offline DougL  United States
Funny how that works.
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
Old 23rd September 2009, 08:33 PM   #59
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
FirstWatt J2
I speculate it uses a 24v dual rail supply
Salas Boards 2018#1 On Order | Hot-Rod DCB1 boards and kits In Stock, PM | M2C Boards, PS and transformers Available PM | Sony VFET CSX2 AL boards In Stock
Old 23rd September 2009, 08:34 PM   #60
R-K Rønningstad is offline R-K Rønningstad  Norway
R-K Rønningstad's Avatar
Default p channels
Nelson, have you asked them if they could do p-channels as well http://www.semisouth.com/products/custom.html ?
Kind regds
Rolv-Karsten
FirstWatt J2Hide this!Advertise here!
An another way to Firstwatt F1? Idefixes Pass Labs 10 5th July 2017 12:02 PM
Subwoofer and Firstwatt F1 tgrauss Subwoofers 10 3rd June 2009 04:29 PM
Fostex and Firstwatt in car? Ipanema Car Audio 2 11th February 2008 05:32 AM
FirstWatt.com Rory Christ Pass Labs 121 31st May 2004 07:02 PM
