FirstWatt J2
FirstWatt J2
Old 12th October 2009, 04:30 PM   #181
bobodioulasso is offline bobodioulasso  Europe
bobodioulasso's Avatar
In other words: The lower resistor, serial connected to the load, develops a voltage across itsef which, through a biasing voltage source, modulates the current source Jfet
Old 12th October 2009, 05:09 PM   #182
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
FirstWatt J2
it's always like that - when you have SRPP
question is - why that resistor is divided in two
anyway - I imagine that two ( identical ) resistors are used to ensure equal Ri of upper and lower halve , looking from load side ..... or adequate output impedance , if you wish ;
imagine that you have just source resistor in upper halve , with value of these two resistors ; that's good enough for Shunt Regulating upper side of Push Pull .
but - these two halves will not have same or "enough" same internal resistance , and result must be in some asymmetric behavior ;
that's usually not of importance in tube stages , where bias voltage is negligible comparing to output swing ( not taking output impedance in account this time ...... or output signal tapping point) but - here - 1V2 certainly isn't same as 2V4 - comparing to overall voltage of 2x20V++
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 12th October 2009, 05:18 PM   #183
I see the upper resistor as a feedback to the current source variations.
Old 14th October 2009, 08:29 AM   #184
Originally Posted by Zen Mod View Post
...imagine that you have just source resistor in upper halve , with value of these two resistors ; that's good enough for Shunt Regulating upper side of Push Pull ...
Aren't we in a single ended topology rather than a push pull one?
Te upper resistor is not in the output signal path but is part of the current source.
Old 14th October 2009, 03:24 PM   #185
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
FirstWatt J2
The SRPP circuit diagrams as seen at John Broskie's Guide to Tube Circuit Analysis & Design have one resistor, and this maximizes the modulation of the current source tube. If you tap the load below the resistor, then you are going for a constant current source.
Tapping off the "middle" of the resistors, that is to say between two resistors, sets a middle performance, which is referred to there as the "mu follower".
Old 14th October 2009, 06:35 PM   #186
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
FirstWatt J2
So with a novices eyes, this 'Aikido mu follower'appears to be a close representation of the J2 simplified circuit.
The two tubes on the left are replaced by 2x 2sk170 on top, and 2sj109 on bottom on the negative rail. Followed by the SemiSouth JFETs.
Of course, I think that's what Nelson said....
Salas Boards 2018 GB Open Click Here to Sign Up! Ends 5/27/18 | Hot-Rod DCB1 boards and kits In Stock, PM | M2C Boards, PS and transformers Available PM | Sony VFET CSX2 AL boards In Stock
Old 14th October 2009, 09:58 PM   #187
The one and only
FirstWatt J2
Hmmmm...
No, that's not it.
Old 15th October 2009, 02:14 AM   #188
ra7 is offline ra7  United States
FirstWatt J2
page 3 is out on 6moons.
Old 15th October 2009, 04:10 AM   #189
Spooky Electric is offline Spooky Electric  Germany
Spooky Electric's Avatar
Mr. Ebaen is keeping us in suspense!
Old 15th October 2009, 04:36 AM   #190
Blues is offline Blues  United States
Blues's Avatar
6moons audio reviews: FirstWatt J2
Life simplified! Leap into the Warpspeed wormhole... http://www.6moons.com/audioreviews/warpspeed/1.html
FirstWatt J2Hide this!Advertise here!
An another way to Firstwatt F1? Idefixes Pass Labs 10 5th July 2017 12:02 PM
Subwoofer and Firstwatt F1 tgrauss Subwoofers 10 3rd June 2009 04:29 PM
Fostex and Firstwatt in car? Ipanema Car Audio 2 11th February 2008 05:32 AM
FirstWatt.com Rory Christ Pass Labs 121 31st May 2004 07:02 PM
