Good afternoon all,
I couldn't sleep last night, a "what if" was floating around my head... I have a Weiss Medea DAC which outputs +27dB on the XLR's. Voltage wise I don't know how to convert, I'm guessing ~18v but it's really high, too high for all of my amps and has caused a headache or two working out how to accommodate it without gagging it in but at the cost of dynamics, a compromise I'm not prepared to concede. As Nelson is already aware, I have also been playing with a Feastrex D9nf wide range driver - reasonably sensitive (around 91dB, 16ohm). It occurred to me that maybe, just maybe it would be possible to run the driver directly from the XLR outputs.... Well, it works, and not only that it is the most incredible sound I have ever heard away from Stax headphones. The detail, the subtleties, the emotion - absolutely incredible. I spoke to Weiss this morning and he was surprised but reassured me that no damage would be incurred to the DAC output. I'd now like to take it a step further. I have the Xvr1 set at ~ 200Hz between the Feastrex and an Eton 11" bass driver, usually feeding a pair of conventional power amps. Firstly - would the XVR1 be happy with an input signal at +27dB? Secondly, would the output stage of the Xvr1 be happy attached directly to the loudspeaker? The financial implications of the discovery are significant, I can now potentially liquidate a considerable chunk of monies that's presently tied up in high end Nordost cables and various amps - and at the same time making a considerable step up acoustically. What are the acoustic implications of taking this route? All thoughts, warnings, condemnations or otherwise most welcome! Steve |
#2 | |
The one and only
No. You can drive 16 ohms with an XVR1, but the power will be miniscule.
#3 |
Many thanks Nelson
With the Weiss I'm sure I'm only an op-amp or two away from something really quite special - I so wish I lived next door... |
| Pass Labs XVR1 crossover | GRollins | Pass Labs | 50 | 2nd January 2012 05:22 PM |
| Pcb for xvr1 ?? | matsj | Pass Labs | 4 | 26th February 2008 05:54 PM |
| Advice for Linkwitz Orion system with Nelson Pass-style pre-amp and amp | GeorgeBoles | Pass Labs | 111 | 27th November 2007 03:17 AM |
| XVR1 active crossover, discrete active stage | promitheus | Pass Labs | 18 | 22nd July 2002 01:29 AM |
| Page generated in 0.08136 seconds (73.93% PHP - 26.07% MySQL) with 10 queries |
