Old 4th September 2009, 10:07 PM   #1
rgheck is offline rgheck  United States
Default Balanced Stereo Pot for Balanced B1?
Does anyone know of a reasonably priced balanced stereo pot suitable for use with a balanced version of the B1? (Such is what I am trying to build.) Failing that, can anyone recommend a reasonably priced stereo pot that will have suitably good tracking that I could use two of them? I don't really want to shell out $375 or whatever for the DACT.
Old 4th September 2009, 10:48 PM   #2
Texas Instruments PGA2310, PGA2311, and PGA2320 or Cirrus Logic CS3310 can do very
tight tracking if you want to go digitally controlled route. Use 2 chips (+ and -) signals
through each channel + PIC controller.
Old 4th September 2009, 10:51 PM   #3
DougL is online now DougL  United States
You are probably better off with a shunt attenuator for tracking.
http://www.kandkaudio.com/linestage.html
Stepped Shunt Attenuator at the bottom of the page.
Doug
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
Old 5th September 2009, 03:05 PM   #4
Thanks for both of these suggestions. The stepped shunt thing looks like an option, though two of them are almost as much as the DACT. I've no clue about the digitally controlled stuff.
Old 5th September 2009, 03:22 PM   #5
Why 2? One of them (its a stereo attenuator) can handle both channels, because you are not attenuating the 2 inputs separately. Because its 1 shunt element, CMRR is preserved.
Doug
Old 10th September 2009, 06:01 PM   #6
Yes, sorry, that was silly. I can build these things, but it doesn't mean I understand them.
Anyway, thanks again for the suggestion. Now another possibly silly question. How exactly does this thing get wired into the circuit? I ask about this both as regards the balanced use and, perhaps before I get that built, the unbalanced use.
Thanks in advance.
unbalanced stereo out to mono summed balanced output Original Burnedfingers Solid State 3 11th January 2009 05:45 PM
balanced stereo audio switch box biovizier Parts 0 5th August 2007 06:16 PM
DACT balanced stereo 10K thommy Swap Meet 0 22nd April 2006 07:17 AM
DACT CT-2 stereo & Balanced Attenuators drubrew Swap Meet 3 15th December 2005 09:42 AM
From two amps stereo to single amp balanced? Cradle22 Solid State 4 17th April 2003 05:16 PM
Page generated in 0.07972 seconds (71.76% PHP - 28.24% MySQL) with 10 queries
