Burning Amplifier BA-2
Old 13th January 2012, 11:50 AM   #961
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
black-red : one secondary
orange - yellow : another one
if that's the case , they're connected as needed , looking at pictures
having them so big is useful .............
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 13th January 2012, 11:54 AM   #962
oiphy is offline oiphy  Norway
diy newbie
oiphy's Avatar
Default *facepalm
Originally Posted by mikojat View Post
I think, 50 VDC you got from V+ and V-? not from V+ and Gnd or V- and Gnd,..Do you?
digging hole to china and going to bury myself....... so emberrased...
yes you're right... but found another fault on the board..... seems that if i connect the left side of the board i get 50 v from + to- but nothing from- to gnd??? se underside of board??? seems to me that there r something not cut away...
will resolder to other side and see.
thank
" If you're going throu hell, keep going"
Old 13th January 2012, 11:55 AM   #963
Zen Mod's Avatar
clarify ....... yay or nay
Old 13th January 2012, 12:00 PM   #964
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally Posted by Zen Mod View Post
make one
The classic : The Dim-bulb Radio Tester
Old 13th January 2012, 12:11 PM   #965
diy newbie
oiphy's Avatar
only psu connected at this time.
1. colors:
pri is blu and brown
sec1 is red black
sec2 is orange yellow
tested psu + to gnd is 24,9v
- to gnd is 25.0v
so guess this is ok for now. wires will be changed and twisted when amp is fired up and stable. will also shield trafo.
going to make bulb tester... or can i use an Amperemeter around 1 fase (live)
thanks
first - search for "bulb tester" ( AndrewT is strong proponnt of that tool , with reason) ;
make one
connect amp via BT (say that 40-60W is good for start)
disconnect amp pcbs from PSU and test just PSU
from pics I see that you connected Graetzs as needed - check polarity 3 times before powering up!
power up and measure voltage on each output
BT will lit brightly and dim after sec-2 if everything is OK
if BT is bright for prolonged time , something is wrong
measure voltage between each + and gnd - you can expect DC voltage in range Vac x 1.41
measure voltage between each - and gnd - same voltage ( opposite polarity , off course)
example - for 18Vac secondaries , you can expect 18x1,41~25Vdc
when you are done with that , report here
but first !! write what wire colors are written on xformer - we need to check did you connected secondaries as needed
Old 13th January 2012, 12:17 PM   #966
Zen Mod's Avatar
OK - for now everything is fine
you can proceed ( with BT ) with output connected
I'm not familiar with these pcbs , so I can't check visually is everything connected as needed
Old 13th January 2012, 12:20 PM   #967
R.I.P.
- to gnd measures 25V
+ to gnd measures 24.9V
You must specify +- and whether dc or ac.
I would expect to see + to gnd showing +24.9Vdc
and - to gnd showing -25.0Vdc
If your meter read + for both supplies, then you must have mixed up (swapped) your test probes.
Primary.
Blu is to Neutral
Brn is to Live.
But in mains wiring you must consider both L & N to be equally dangerous.
Due that condition, both L & N are insulated to the same standards.
This allows one to swap the transformer Blu & Brn to the "wrong" terminals. Some times a transformer behaves/performs slightly better when wired up "correctly" and sometimes when wired "wrong".
But ensure the mains fuse is still in the LIVE side.
regards Andrew T.
Old 13th January 2012, 12:24 PM   #968
mikojat is offline mikojat  Indonesia
mikojat's Avatar
I see, seem the negative rail connected to ground...If yes, cut it...cutter will work easy.. , so, is no wonder if you can't measure between V- and Gnd
Old 13th January 2012, 12:34 PM   #969
diy newbie
oiphy's Avatar
ok. BT complete. connected and it litt up in 1-2 sec and turned off.
so now I guess I shold connect the psu to main board?
Old 13th January 2012, 12:37 PM   #970
diy newbie
oiphy's Avatar
http://dl.dropbox.com/u/57077275/downside%20fualt.jpg
is it this u see??
Burning Amplifier BA-2Hide this!Advertise here!
The Burning Amp Festival-Burning Gadgets Preview Zen Mod Everything Else 116 25th June 2015 06:38 AM
Burning Amplifier BA-2 Nelson Pass diyAudio.com Articles 5 14th September 2011 06:11 PM
