Burning Amplifier BA-2
Old 13th January 2012, 11:43 AM   #951
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
I just replied on your PM , with solution for that
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 13th January 2012, 12:21 PM   #952
oiphy is offline oiphy  Norway
diy newbie
oiphy's Avatar
Default trying again
http://dl.dropbox.com/u/57077275/downside.jpg
http://dl.dropbox.com/u/57077275/upside.jpg
http://dl.dropbox.com/u/57077275/004.JPG
http://dl.dropbox.com/u/57077275/005.JPG
http://dl.dropbox.com/u/57077275/006.JPG
http://dl.dropbox.com/u/57077275/007.JPG
http://dl.dropbox.com/u/57077275/008.JPG
http://dl.dropbox.com/u/57077275/003.JPG
lets hope this works
thank you zen master
" If you're going throu hell, keep going"
Old 13th January 2012, 12:21 PM   #953
don't upload.
ATTACH
regards Andrew T.
Old 13th January 2012, 12:25 PM   #954
mikojat is offline mikojat  Indonesia
mikojat's Avatar
They are...
Old 13th January 2012, 12:28 PM   #955
the or/yel are not twisted on their route to the rectifier.
I wonder if the red/blk are similarly untwisted?
regards Andrew T.
Old 13th January 2012, 12:33 PM   #956
Zen Mod's Avatar
oiphy
now I see that you resize them nicely , so you can directly upload them here
reply-manage attachments etc , same as with first pic you attached here
you can use DB for larger ones
edit : ups - just first one is adequate in size for attaching here
Old 13th January 2012, 12:34 PM   #957
diy newbie
oiphy's Avatar
Default heyyyy
why cant I do that...???
oh wait .... only get that file is to big....
ARGHHHHH..
http://dl.dropbox.com/u/57077275/overview%20001.JPG
Old 13th January 2012, 12:39 PM   #958
diy newbie
oiphy's Avatar
for now they'r not twisted. but the problem is getting it up and running, or should I say them (have 2 monoblocks)
for now Im getting 50 vdc to psu when 2 sec is connected... look at pics.. see I disconnected one sec. and then I have 25v soooooooo whats wrong ??
Old 13th January 2012, 12:41 PM   #959
mikojat's Avatar
I think, 50 VDC you got from V+ and V-? not from V+ and Gnd or V- and Gnd,..Do you?
Old 13th January 2012, 12:45 PM   #960
Zen Mod's Avatar
first - search for "bulb tester" ( AndrewT is strong proponnt of that tool , with reason) ;
make one
connect amp via BT (say that 40-60W is good for start)
disconnect amp pcbs from PSU and test just PSU
from pics I see that you connected Graetzs as needed - check polarity 3 times before powering up!
power up and measure voltage on each output
BT will lit brightly and dim after sec-2 if everything is OK
if BT is bright for prolonged time , something is wrong
measure voltage between each + and gnd - you can expect DC voltage in range Vac x 1.41
measure voltage between each - and gnd - same voltage ( opposite polarity , off course)
example - for 18Vac secondaries , you can expect 18x1,41~25Vdc
when you are done with that , report here
but first !! write what wire colors are written on xformer - we need to check did you connected secondaries as needed
Burning Amplifier BA-2Hide this!Advertise here!
The Burning Amp Festival-Burning Gadgets Preview Zen Mod Everything Else 116 25th June 2015 07:38 AM
Burning Amplifier BA-2 Nelson Pass diyAudio.com Articles 5 14th September 2011 07:11 PM
