Burning Amplifier BA-2
Old 16th December 2011, 10:15 AM   #911
Backbones is offline Backbones  United Kingdom
Originally Posted by Zen Mod View Post
do your homework - read all Papa's papers , if not for your own pleasure - then from respect for his sharing ; papers are written to be read .
adjust DC offset on output with P2 on output stage
He's absolutely right.
Old 16th December 2011, 08:52 PM   #912
nikosgrgr is offline nikosgrgr  Greece
I told you about possible differences between source resistors (in value )
those 150 ohms resistors aren't "bias resistors" in any meaning ; they're gate stoppers , intended for preventing oscillations and somewhat for shaping frequency response of mosfets
Dear Zen Mod,
Appreciating your "refer to "on fundamental references.
I myself have studied the manual very thoroughly.
If you have the time to read with more attention you will see that i have pointed out on post 901 on this thread that I do not have any other turns to trim on P102.
Additionally
When you suggested to check the source resistors for possible variances i thought that measuring also the 150 ohm resistors is a good idea in terms of providing a more complete picture.
If this measurement is irrelevant to the problem i do apologize.
Finally please do not make any assumptions that lead to falls conclusions.
In any case thanks for all your help and support.
Old 16th December 2011, 09:05 PM   #913
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Measure the source resistors to see if the fets are sharing current equally or close. If you followed the schematic exactly, they should be the 1R 3W resistors.
Old 16th December 2011, 09:38 PM   #914
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
nobody is perfect , except me ....... and (just ) maybe Papa .....
anyway - fact is that you mention gate resistors as possible culprit in individual biasing of mosfets ; that can lead to confusion any other greenhorn reading these posts in future ....
turn off amplifier ;
turn pot P2 approx. to middle position ;
if offset is positive - solder 220K resistor across R25
if offset is negative - solder 220K resistor across R26
turn on , set offset with P2
setting offset - referring to this attached schematic :
(FE doesn't have anything with output offset )
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 16th December 2011, 10:31 PM   #915
buzzforb's Avatar
Is this to compensate for possibly unusual difference in N vs P parts? Reason for checking offset polarity is to identify which side is in need of compensation.
Old 16th December 2011, 10:36 PM   #916
Zen Mod's Avatar
sort of
nothing to write home about
Old 17th December 2011, 02:01 PM   #917
Nelson mentions using some large capacitors between the BA-2 front end and any voltage regulator. Any idea how large?
I'm using Salas SSLV1.1.
Old 17th December 2011, 02:28 PM   #918
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Originally Posted by Backbones View Post
Any idea how large?
high impedance load = smaller cap
lower load impedance = bigger cap
Old 17th December 2011, 02:30 PM   #919
Zen Mod's Avatar
if reg is situated near BA FE , you don't need additional decoupling , especially with shunt regs , where too much of capacitance on output is counter-productive
if reg is situated at more than , say ,10cm from BA FE , you'll need some local decoupling , just in case
Old 17th December 2011, 02:36 PM   #920
Dear Buzzforb hi,
Olready did that
Post #907
I do not see significant value differences on the source resistors .
Left channel
IRFP9240 (40mV bracket)
1ohm
1ohm
1,1ohm
1,1ohm
1.1ohm
Right channel (10mV bracket)
IRFP9240
1,1ohm
1,1ohm
1,1ohm
1,1ohm
1,1ohm
Burning Amplifier BA-2Hide this!Advertise here!
The Burning Amp Festival-Burning Gadgets Preview Zen Mod Everything Else 116 25th June 2015 06:38 AM
Burning Amplifier BA-2 Nelson Pass diyAudio.com Articles 5 14th September 2011 06:11 PM
