Old 18th February 2011, 01:03 PM   #671
Originally Posted by Zen Mod View Post
I really can't remember how this ended in this thread
Sometimes you've just got to go where the mood takes you.
Old 24th February 2011, 10:02 PM   #672
In spite of my uncertainty on the previous page I have gone ahead and I have been running the amp (one monoblock) on full mains power and nothing is smoking.
However, Nelson refers to setting P201 to adjust the Drain voltage of Q203 to 0 volts.
Do I measure across resistor R215 for this?
Chris
Old 25th February 2011, 09:50 AM   #673
nightrush's Avatar
If I understood Nelsons instructions right, you want to measure the voltage between the drain-pin and GND actually. However, this adjustage isn't very critical, as any dc will be blocked by the cap anyway.
EDIT: We want some pictures, instantly
Best Regards, Florian
Old 25th February 2011, 12:28 PM   #674
Thanks Florian,
I'll measure that anyway.
Here are some photos. If my chum doesn't come through with the other chassis then I'll have to transfer the whole thing. At the moment I have 250mV across the source resistors and the heatsinks are barely warm after 15 minutes.
Chris
Old 25th February 2011, 01:11 PM   #675
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
Let it run for 4 hrs like this and see where it goes. If it can take it, double the bias, or order another set of outputs!
Nice work!
Old 25th February 2011, 04:03 PM   #676
I've pushed the bias up to 400mV and the heatsink temperature is rising to comfortable heat, however, the ambient temp in my workshop is about 12 deg C so I'm it's going to be running hotter in the house.
Chris
Old 27th February 2011, 08:28 AM   #677
joda is online now joda  Italy
Hi friends
A simple question:
You can make a power supply to a BA2 +40-0-40 V?
can be dangerous?
I have at home a pair of transformers 28 0 28 AC,,,,,
any input?
rgds
Old 27th February 2011, 12:15 PM   #678
Tea-Bag's Avatar
Not with the default input boards....There is a cascoded design Jim M made, that uses this, although he is using around a 36-40v tranny. I am using the same boards and tranny range.
Old 28th February 2011, 01:54 AM   #679
The one and only
Nelson Pass's Avatar
Originally Posted by Backbones View Post
Any reason not to use 47K resistor instead of 47.5K on BA-2 front end at resistors R203 and R204?
A wide range of value is OK. The false precision of 47.5K
is simply the result of using my favorite resistor type.
Old 28th February 2011, 05:17 PM   #680
Strange question to ask but how loud should the amp be? I've turned the pre-amp volume control to 3/4 of the way round and I'm just getting a reasonable output. The exposure amp on the other channel is too loud to listen to. Heatsinks are warm to hot at 410mV across the output resistors. Nice sound when I can hear it though! Running it in single-ended mode.
Any thoughts?
Chris
Burning Amplifier BA-2 Nelson Pass diyAudio.com Articles 5 14th September 2011 06:11 PM
The Burning Amp Festival-Burning Gadgets Preview Zen Mod Everything Else 115 27th October 2007 05:50 PM
Page generated in 0.11512 seconds (79.54% PHP - 20.46% MySQL) with 11 queries
