Burning Amplifier BA-2
Old 19th January 2011, 06:44 PM   #631
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Papa use that way in his FW amps ;
reason is simple - cleaner ground and prevented possible xformer buzz , in case of slightest un-symmetry of secondaries
Naim wakoos use same technique , in their amps , if I remember correctly
reasons are completely high fidelity - hard work for every little detail
result is cumulative
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 19th January 2011, 10:26 PM   #632
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally Posted by Backbones View Post
deliberately using more than one secondary winding each with their own diode bridges
One step further : more than one secondary with their own diode bridges, and more than one transformer per channel.
(for examples, see AMT Class A power amp models of Metronome-T)
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 21st January 2011, 09:35 AM   #633
Backbones is offline Backbones  United Kingdom
Just ordered some BA-2 boards.
Have there been any design changes since the last lot?
Chris
Old 21st January 2011, 10:02 AM   #634
cviller is offline cviller  Canada
cviller's Avatar
It has been a while since I did the changes, so this is from an email I wrote back then:
BAGS
- Fix error ±
- Updated version number and date
- Added extra holes 120mm and 60mm apart the other way
- Size: 130x70 mm
BACO
- Increased size to 250x50
- Adjusted holes to 80mm and 5mm from board edge
- Updated version
- Deleted one set of diodes and moved the others in center
- Size: 250x50 mm
BASO
- Same as BACO
- Size: 250x50 mm
BACB
- Resized to 50x50mm
- Moved holes 5mm from edge
- Updated text
- Size 50x50 mm
BASB
- Resize to 50x60mm (difficult to get down to 50x50 due to elna silks)
- Updated text
- Changed the S wire routing
- Size 60x50mm
Old 21st January 2011, 10:11 AM   #635
cviller,
Looks like a lot of hard work. Many thanks and much appreciated.
Chris
Old 21st January 2011, 10:13 AM   #636
cviller's Avatar
Basically, the main difference is that output and bias boards have become slightly larger to provide a standard for boards at diyAudio moving forward.
Old 21st January 2011, 10:16 AM   #637
Just broke out in a sweat when I saw the size increase but my ruler says I can still fit the boards in the chassis.
Old 21st January 2011, 04:56 PM   #638
Forsman is offline Forsman  Sweden
Forsman's Avatar
Excuse me for asking a novice question but what differs the single ended version from the complementary version? Which one is right for me?
kind regards
/Forsman
Old 21st January 2011, 05:05 PM   #639
Zen Mod's Avatar
look for difference in output power
Old 21st January 2011, 06:47 PM   #640
flg is offline flg  United States
flg's Avatar
And output spectra of harmonics
"It was the perfect high end audio product: Exotic, inefficient, expensive, unavailable, and toxic." N.P.
Burning Amplifier BA-2Hide this!Advertise here!
The Burning Amp Festival-Burning Gadgets Preview Zen Mod Everything Else 116 25th June 2015 06:38 AM
Burning Amplifier BA-2 Nelson Pass diyAudio.com Articles 5 14th September 2011 06:11 PM
