#581 | |
0.28 degrees per Watt dimensions 400*200*40 it's definitely warm to the hand, takes maybe an hour before the temperature is fully stabilised, most of the way there in 30 minutes. |
#582 |
Formerly Thanh1973
If you answer post #574
Then I or someone else can be of more assistance
"No, this sucker's electrical, but I need a nuclear reaction to generate the 1.21 gigawatts of electricity I need." |
#583 |
Not having done this before I can't answer on the bias current, I suppose I'll aim at 250mA, but the supply voltage will be 25V on each rail.
#584 |
Thanks Bob,
I'll have another look at that article tomorrow and see if it's any easier for a good night's sleep. Best wishes, Chris |
#585 | |
I like to chose 20°C above ambient, it suits to every season without fingers burning. |
#586 |
I should have said "Suppose you can accept a temperature rise of 30°C..."
Of course acceptable heat sink temperature rise is a personal choice. Papa says about 55°C is decent. Each of us balance the cost of heat sinks and how big the amp must be to accommodate them and acceptable sink and junction temperatures. Often we reach different conclusions. Where you live and whether you are air conditioned in the summer determine the spread between ambient and heat sink. When home in the summer I limit my home to a bit less than 25°C so I can accept a 30°C rise. Your home may be hotter or you may not want to have heat sinks so warm that you cannot touch them indefinitely. Adjust the rise and required heat sink to taste. If my son was allowed to set the indoor temperature I could almost get away without heat sinks. |
#587 |
No real reason why the amp should not run a little hotter than 55°C, that's only a comfortable rule of thumb that avoids that small children and pets don't burn their curious little fingers - high reliabilty is an added bonus
In many commercial amps heatsinks run a lot hotter and are still reliable. Have fun, Hannes
fresh matched IRFP240/IRFP9240 fets || AlephJ/JX-kitsF5 transistor kits || Burning Amp BA-1/2/3 transistor kits |
#588 | |
Formerly Thanh1973
Actually let me put it another way. If you have two of those heatsinks ie 40cm x 15.5cm x 4cm (one per channel) then you will have no issues dissipating 100W of heat per channel you could probably go as high 130W without issues. Based on the 100W figure you can bias at 2A total per channel using +/-25V rails. Start with that then if you want more use the hand test as posted by Nelson/Zen Mod. If you only have one of those heat sinks then you need to half the bias (ie 1A per channel total) then slowly increase using the hand test.
"No, this sucker's electrical, but I need a nuclear reaction to generate the 1.21 gigawatts of electricity I need." Last edited by Melon Head; 13th January 2011 at 07:21 PM. |
#589 |
#590 |
Thanks Melon Head,
Very useful. I'm not sure what is required to bias the circuit. Reading Nelson's instructions I get the impression that one measures across the 1 ohm source resistors of the output stage for voltage which equates with current. 250mV for 250mA. Another question from this is during this test procedure what does one put across the speaker output terminals? Some sort of dummy load? Best wishes, Chris |
| Burning Amplifier BA-2 | Nelson Pass | diyAudio.com Articles | 5 | 14th September 2011 06:11 PM |
| The Burning Amp Festival-Burning Gadgets Preview | Zen Mod | Everything Else | 115 | 27th October 2007 05:50 PM |
| Page generated in 0.11527 seconds (82.01% PHP - 17.99% MySQL) with 11 queries |
