Burning Amplifier BA-2 - Page 57 - diyAudio
Old 12th January 2011, 07:27 AM   #561
h_a is offline h_a  Europe
h_a's Avatar
I think your heatsink but with twice its height could be barely sufficient for the ~75 W power dissipation.
However, do not forget, you can always reduce outputstage bias to fit your heatsinking.
High Octane phono preamp Wiki
Old 12th January 2011, 11:31 AM   #562
two of these, one on top of the other will increase dissipation by about 40%.
Two side by side or back to back will increase dissipation by ~100%.
Side by side spaces the FETs too far apart.
Back to back with the sinks clamping the devices would work if this is the top most part of the amplifier.
Two channels at full bias would probably require 4 of those sinks.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 12th January 2011, 12:11 PM   #563
Andrew,
I have a heatsink here which measures 20cm across by 4cm deep with height of 15.5cm.
Is this enough?
Best wishes,
Chris
I'll post a photo in a minute.
Old 12th January 2011, 12:42 PM   #564
As you can see there are two of these heatsinks bolted together.
Chris
Old 12th January 2011, 01:06 PM   #565
If these heat sinks (from picture) are for one channel they will bi sufficient. Do you know theirs Rth
Old 12th January 2011, 01:16 PM   #566
No. These heatsinks come from the Italian company MODU with the larger model of the Pesante Dissipante.
Chris
Old 12th January 2011, 01:43 PM   #567
download the free software for simulating heatsink performance.
or
look up datasheets until you find a very similar heatsink and read off the data.
regards Andrew T.
Old 12th January 2011, 03:54 PM   #568
I didn't think they would have the data but they have. Well done MODU.
The data (which is attached) for a heatsink 400x 160x 40, (which means two of the 200x160x40 bolted to a joining bracket), at 25 degrees C ambient and Rt((degrees C/W) of 0.23.
For a TO3-P device, multiplied by 6, Max power dissipation (6xTO3-P) is 375W per heatsink.
Old 12th January 2011, 04:28 PM   #569
Having looked through Farnell heatsinks I have found one that looks very similar to those on the other chassis I was hoping to use for the amp.
This chassis has smaller heatsinks than the MODU design, measuring 300 width, 120 depth and 40 height similar to Forsman's.
I am getting a K/W of about 0.35 for this heatsink, looking at the graph supplied on the datasheet from Farnell.
Old 12th January 2011, 04:31 PM   #570
delta T s-a = Rth s-a * P
Ta = ambient.
375W into a pair of sinks gives delta T s-a ~ 86C
When room is hot say Ta=30degC the heatsink will be at 116degC and Tc ~130degC.
0.23C/W does not come close to being adequate.
Does each in the 6pair dissipate >30W?
regards Andrew T.
The Burning Amp Festival-Burning Gadgets Preview Zen Mod Everything Else 116 25th June 2015 07:38 AM
Burning Amplifier BA-2 Nelson Pass diyAudio.com Articles 5 14th September 2011 07:11 PM
Copyright 1999-2017 diyAudio
