Burning Amplifier BA-2
Old 27th December 2010, 03:21 PM   #551
Backbones is offline Backbones  United Kingdom
Sorry to go on about the power supply but is there a reason for the four 1ohm resistors being placed in parallel between the two capacitors? Does one get the same affect using a single resistor say 0.25 ohm at 25W?
Chris
Old 27th December 2010, 03:40 PM   #552
BobEllis is offline BobEllis  United States
BobEllis's Avatar
You get the same filtering effect. Watch the derating factor if you don't mount the 25W resistor to a proper heat sink, though. For example, a Vishay Dale RH025 must be derated by at least 50% if you don't mount it. Mounting it to a reasonably thick chassis is enough, but you still must derate it slightly.
With 4 x 3W resistors, you spend a dollar instead of 6 and don't need to drill and tap mounting holes, etc. I'm cheap and lazy, you know which way I'd go.
Old 27th December 2010, 04:17 PM   #553
Nothing wrong with minding the pennies.
When you talk of 'derated' do you mean you have to reduce its rated resistance or power?
Chris
Old 27th December 2010, 04:41 PM   #554
BobEllis's Avatar
Derating refers to power handling. For example see http://www.mouser.com/catalog/specsheets/rhnh.pdf A 25W resistor would be good for unmounted operation.
Old 10th January 2011, 04:08 PM   #555
Forsman is offline Forsman  Sweden
Forsman's Avatar
Default BA PCBs
Does any one have an update on how things are going with the new batch of BA boards?
Kind regards
/Forsman
Old 10th January 2011, 06:55 PM   #556
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
They will be in the store in about a week, maybe less, plus lots more cool boards.
At the moment they are sitting in my living room, so they DO exist!
Mark
"The geek shall inherit the earth"
2017 Burning Amp is November 12 in S.F. Thread here on diyAudio:
http://www.diyaudio.com/forums/clubs...francisco.html
Old 10th January 2011, 07:01 PM   #557
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Lazy Mod !
give us prun !!
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 10th January 2011, 08:06 PM   #558
Forsman's Avatar
Mark
lovley, I will keep sharp look out at the store.
/Forsman
Old 11th January 2011, 09:57 PM   #559
Forsman's Avatar
Default Heat sinking
Ive found a couple of nice heat sinks for a reasonable price but Im not sure they will suffice. What is your take on a pair of these, are they sufficient or do I probably need larger ones?
12*4*1.56 in
kind regards
/Forsman
Old 11th January 2011, 10:10 PM   #560
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
I dont think so. If you could stack another set on stop you may be talking. Thermal epoxy could be used for that.
Alternatively, you could just bias lower and use 1 or 2 outputs pairs.
Salas Boards 2018#1 On Order | Hot-Rod DCB1 boards and kits In Stock, PM | M2C Boards, PS and transformers Available PM | Sony VFET CSX2 AL boards In Stock
Burning Amplifier BA-2Hide this!Advertise here!
The Burning Amp Festival-Burning Gadgets Preview Zen Mod Everything Else 116 25th June 2015 06:38 AM
Burning Amplifier BA-2 Nelson Pass diyAudio.com Articles 5 14th September 2011 06:11 PM
