Burning Amplifier BA-2
Old 30th November 2010, 09:36 PM   #521
JimM is offline JimM  United States
You can see circuit on post 279 and pictures of the amp on post 454, for cascode boards.
Old 2nd December 2010, 04:28 PM   #522
Backbones is offline Backbones  United Kingdom
Here are some views of the completed power supply. To test without the amp what do people suggest. I'd like to see how much current and voltage I have so what about some light bulbs?
Chris
Old 2nd December 2010, 08:01 PM   #523
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
why voltage / current ?
measuring just voltage , using either variac or bulb-trick for first powering up , is completely sufficient for evaluation
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 3rd December 2010, 02:07 PM   #524
OK I seem to be getting 25.3V on each rail.
I have read here that some of you have had some very hot thermistors but after 30mins since I turned the power supply on I can not feel the CL60s getting warm at all.
The diodes haven't even warmed up yet either. Mind you they are rated at 30A, 1200V each.
Chris
Old 3rd December 2010, 02:35 PM   #525
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
do you have the outputs connected? Is it a burning amp?
Salas Boards 2018#1 On Order | Hot-Rod DCB1 boards and kits In Stock, PM | M2C Boards, PS and transformers Available PM | Sony VFET CSX2 AL boards In Stock
Old 3rd December 2010, 02:39 PM   #526
Well I'm driving a couple of 100watt light bulbs on each power source and they are warm but no sign of burning. I'm going to have to wait for the BA2 boards before I can really put things to the test.
Chris
Old 3rd December 2010, 02:57 PM   #527
Zen Mod's Avatar
Chris
that's logical
you don't have power draw from PSU and everything must stay cold
Old 3rd December 2010, 06:58 PM   #528
R.I.P.
CL60s in the primary feed? These pass mains Live. DO NOT touch them.
regards Andrew T.
Old 5th December 2010, 04:14 AM   #529
reytnz is offline reytnz  New Zealand
reytnz's Avatar
Chris
You don't have to wait for the BA2 boards, you can test it using a dummy load...
This is just my approximation based on your test set-up, I presume the load light bulb is rated 100W ,230-240 volts, connected to your power supply output ~25Vdc, By deduction, bulb would draw ~10Watts, producing maybe a little glow in the bulb, The BA2 is expected to draw 300W at full blast bias, stereo. I would suggest to find a DC halogen lamp rated at 100W-150W (or equivalent say two 12 volts 50w-75w connected in series ) and connect as load to give your PSU a really good workout..
and also I'm a little bit worried with your air cooled diodes.
Old 5th December 2010, 05:19 AM   #530
reytnz's Avatar
Default 24Vdc 100-150Watts Halogen Lamp
I would suggest to find a DC halogen lamp rated at 24Vdc 100W-150W (or equivalent, say two 12-volts 50w-75w h/lamp connected in series ) and connect as load to give your PSU a really good workout..
Burning Amplifier BA-2Hide this!Advertise here!
The Burning Amp Festival-Burning Gadgets Preview Zen Mod Everything Else 116 25th June 2015 06:38 AM
Burning Amplifier BA-2 Nelson Pass diyAudio.com Articles 5 14th September 2011 06:11 PM
