Burning Amplifier BA-2
Old 14th March 2013, 08:41 PM   #1061
mattattnet is offline mattattnet  United States
Default and more
regards, Matt
Old 15th March 2013, 11:15 AM   #1062
Backbones is offline Backbones  United Kingdom
Hi Matt
That photo above, second from right, shows the speaker out terminals right? The central connection of each terminal, one is wired for output from the power boards and one from ground, correct? Oh I think I can see you have.
Chris
Old 15th March 2013, 11:21 AM   #1063
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Is that plate holding the mosfets down?
...Shape the sound , Man!
Old 15th March 2013, 11:22 AM   #1064
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
how you wired that XLR and switch above ?
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 15th March 2013, 11:54 AM   #1065
Default BA-2 problems
Backbones: Yes, the OUT from the output boards goes to the + speaker out terminal. The (-) speaker out terminal goes to the signal ground. Thanks!
buzzforb: The plate is just holding the output board against the sink. There are 6 standoffs on the board, the plate holds the board stable, and I verified that no metal from the holddown plate is touching any exposed traces on the board. Each MOSFET is secured to a tapped hole on the sink with compound and pads between the mosfet and sink. Thanks.
ZM: I have rca and xlr inputs. switch is used to ground pin 3 of the xlr to pin 1 when the rca input is used. All connections have been verified as correct. Thanks.
Matt
Old 15th March 2013, 05:33 PM   #1066
Hi Matt,
I know this might sound wrong headed but have you actually wired up some speakers (not the good ones) and listened?
After all if the bias has been set and you can adjust the dc offset then the power boards are working fine. Could be the front end by a process of elimination.
Chris
Old 15th March 2013, 06:36 PM   #1067
Default trouble with BA-2 mono
Backbones: Hi Chris, yes, I did hook one up, did get sound, very quiet, then stopped as I increased the volume, as the 1.5amp fuse I had onboard blew. Same result with both monoblocks and even one monoblock with another gain stage board that I assembled with totally new components, all checked for proper values.
I have looked at these front end boards many times, and checked the components for orientation, value, etc, but plan to do that all over again this weekend.
Matt
Old 25th March 2013, 10:58 AM   #1068
Hi Matt,
How are things progressing? Two things that came to mind whilst doing nothing in particular over the weekend were: fake components on the semiconductor side and the other as to whether you have disconnected the front end and fed a signal into the power boards directly to see how they behaved.
Best wishes,
Chris
Old 26th March 2013, 03:33 PM   #1069
Hi Backbones:
I am in the process of totally rebuilding one of the gain boards with new parts to see if I can get the proper voltage gain at the board output.
I had worried about counterfeits, too, but the 2SK parts all tested within the appropriate ranges using the listed testing procedures within this string and other Pass strings.
Once I get that done (having a hip replacement in about 2 weeks, so it is putting DIY on the back burner again) I will report back.
Thanks,
Matt
Old 3rd June 2013, 04:21 PM   #1070
mns80 is offline mns80  Finland
Hi Guys, what do you think about these? I am thinking BA-2 output paired with BA-3b. Cut these babies in half and use two pieces per mono. ~6 FETs per corner was the idea but that is still on the drawing table..
Burning Amplifier BA-2Hide this!Advertise here!
The Burning Amp Festival-Burning Gadgets Preview Zen Mod Everything Else 116 25th June 2015 07:38 AM
Burning Amplifier BA-2 Nelson Pass diyAudio.com Articles 5 14th September 2011 07:11 PM
