Burning Amplifier BA-2
Old 11th September 2012, 05:48 PM   #1041
nikosgrgr is offline nikosgrgr  Greece
Default Cascode on BA-2 Front End
Is there any schematics diagram for cascoding the BA-2 front end?
Can we use as e reference the cascode section from F5 V3 schematics and implemented to work on BA-2?
Old 11th September 2012, 06:08 PM   #1042
flg is offline flg  United States
flg's Avatar
I don't remember any "official" schemo but up to 30-32V -V, NP has given the fearless amplifier builder the go-ahead. The top side (TAIL) of the diff pair uses a resistor to loose unecessary voltage...
Beyond that, 8-10V on the JFETs is a good number in my experience. BJT's are said to perform better as cascodes. You still need to bias the second stage appropriately...
"It was the perfect high end audio product: Exotic, inefficient, expensive, unavailable, and toxic." N.P.
Old 11th September 2012, 11:24 PM   #1043
JimM is offline JimM  United States
Nikosgar I will refer you the schematic I did and the amp I built see the following post in this thread. Post 279,416,417,420,449,453,454. See if this will get you started.
JimM
Old 12th September 2012, 06:34 PM   #1044
Dear flg
I have already 30 V rails and want to go up to 50 V in order to have more power.
Old 12th September 2012, 06:53 PM   #1045
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
JimM sold a few boards to me which I used in BA2 running about 55v.
I would see if he can help you out. they work fine.
Salas Boards 2018#1 On Order | Hot-Rod DCB1 boards and kits In Stock, PM | M2C Boards, PS and transformers Available PM | Sony VFET CSX2 AL boards In Stock
Old 12th September 2012, 07:25 PM   #1046
JimM
Dear JimM,
Thanks for pointing to the right direction.
I have seen your schematics and implementation (excellent & inspiring).
Questions
I have notice on your final schematic layout that for R203-R204 you are using different values (200 K & 150 K) why? (in your first schematics you had both on 200K).
According to the BA-2 manual those two are equal and are changing the gain (47.5K around 15db (initial setting by NP) - 100K /20db-150K /23db)
Can you post your PCB layout
Thanks for all the help and support
Old 12th September 2012, 07:39 PM   #1047
please !!!!! do !!!!!! that would be wonderful !!!!!! if you can
Old 13th September 2012, 03:43 AM   #1048
nikosgar I think the final value I ended up with in R203 and R204 was 97.7k in both places, the 200k and 150k was wrong, it should have been one or the other in both places. I choose the 97.7k value to match the output of my benchmark DAC. If you will send me a P.M. with email address I will respond, and yes I do have som boards left.
JimM
Old 13th September 2012, 06:40 PM   #1049
JimM
Dear JimM
You got mail
Old 26th February 2013, 10:58 PM   #1050
joesch1999 is offline joesch1999  United States
Default Joes Ba2 please help
OK I am a green horn when it comes to building amps, I can read schematics but I need to know when mr pass says standard relating to capacitors or resistors as far as voltage wattage etc. is concerned what is standard? I can see in the schematics it calls for a 1000 uf cap but what is the voltage also the resistors the big ones say 3 watts the others must be the standard thing lol, I have the ba2 boards, I need to be pointed to a decent case and power supply, some links would help, I would like to thank anyone who helps me out ahead of time.
Burning Amplifier BA-2Hide this!Advertise here!
The Burning Amp Festival-Burning Gadgets Preview Zen Mod Everything Else 116 25th June 2015 06:38 AM
Burning Amplifier BA-2 Nelson Pass diyAudio.com Articles 5 14th September 2011 06:11 PM
