Burning Amplifier BA-2
Old 23rd January 2012, 10:22 AM   #991
R.I.P.
be careful.
Higher bias in the output stage also pulls higher bias in the preceding stages.
Changing the bias of these transistors can/will move them to a different operating point where their parameters are different.
I think these changes can change the stability margins of the standard amplifier.
One that shows no oscillation during any testing, may now show damped oscillation on a part of a signal waveform.
regards Andrew T.
Old 23rd January 2012, 10:30 AM   #992
oiphy is offline oiphy  Norway
diy newbie
oiphy's Avatar
so for now its probably better to leave bias at 250mA and finnish the BA3 merge them and listen?
When you say osilate what exactly do you mean? is this what I'm seeing on output as it moves a little round +- some mV? this normal?
as I've said earlier I'm a newbee....so please have patience with me.
" If you're going throu hell, keep going"
Old 23rd January 2012, 10:31 AM   #993
Backbones is offline Backbones  United Kingdom
I have the bias set at 400mV. At this bias the heatsinks stay within the temp suggested by Mr. Pass. Nelson has written that the mosfets do benefit from running at a higher bias if the heatsinks are up to it and all I can say is that the amp sounds very good at 400mV.
What is your DC offset?
Old 23rd January 2012, 10:39 AM   #994
Zobel networks.
I have been using a Zobel across the loudspeaker wires for some years. If values and components are chosen properly one can get tighter bass, less brittle and hard upper frequencies. Since I took out the RC components of the BA-2 board for the Salas reg I have noted an immense clarity to the sound but also some hardness creeping in to the upper mid frequencies and perhaps a little too much upper frequency energy. After scratching my head a little I reversed the Zobel so that the cap made contact with ground and the resistor on the +ve terminal. This has abolished the hardness and over bright upper fequencies whilst retaining the overall clarity.
Old 23rd January 2012, 10:42 AM   #995
diy newbie
oiphy's Avatar
dc offset 0v to -0.5mV moves a little around. meassured from +- binding post.
Old 23rd January 2012, 10:47 AM   #996
That's good. Why don't you listen to the amps at this bias and then if you want to at a later date turn up the bias and let us know what differences you can hear.
Old 23rd January 2012, 10:54 AM   #997
diy newbie
oiphy's Avatar
ok. will then finish both amps,(2x mono) listen and report back later. will take some time.... home with sick kid today so... later.
anyhow. all help is mutch appriciated.
wish you all an exelent week
Old 23rd January 2012, 01:12 PM   #998
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Originally Posted by Backbones View Post
......After scratching my head a little I reversed the Zobel so that the cap made contact with ground and the resistor on the +ve terminal. This has abolished the hardness and over bright upper fequencies whilst retaining the overall clarity.
can you imagine amount of head-scratching if someone , during the night , again rotate position of cap and resistor in Boucherot , and you don't spot any difference ..........
block cap and resistor pretty much don't care where their head is , only ppl take too much care of it
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 24th January 2012, 11:02 AM   #999
Originally Posted by Zen Mod View Post
...someone , during the night , again rotate position of cap and resistor in Boucherot , and you don't spot any difference ..........
But who would do a thing like that?
Old 24th January 2012, 11:13 AM   #1000
Zen Mod's Avatar
RC chain is R and C series connected - between two nodes ;
it's irrelevant is it RC or CR
Burning Amplifier BA-2Hide this!Advertise here!
The Burning Amp Festival-Burning Gadgets Preview Zen Mod Everything Else 116 25th June 2015 06:38 AM
Burning Amplifier BA-2 Nelson Pass diyAudio.com Articles 5 14th September 2011 06:11 PM
