Old 1st September 2009, 10:57 AM   #1
Default Mini Aleph Problem
Hi guys,
i just built a mini aleph using BrianGT's board. However when power is applied, the output saw a DC offset of -15V. I am using a +/-16V power supply. Could you guys help me with this problem as i cannot figure out what went wrong.
Thanks!
Old 1st September 2009, 08:16 PM   #2
vdi_nenna's Avatar
Send a message via Yahoo to vdi_nenna
Sounds like a bad mosfet.
Did you double check your wiring?
I build, therefore I am.
Old 1st September 2009, 08:30 PM   #3
vdi_nenna's Avatar
On the Mosfets, what's the voltage at the Source and Drain reading?
Check the voltages around the .47 ohm power resistors. My schem shows R18 and 19 as .47 Ohm 3w.
Old 1st September 2009, 10:14 PM   #4
Yup double checked it a few times. I have 2 boards, one is working while the other is not. What i did for checking is that i compare both board's parts to see if they are equal, and they are. So i would assume that its right.
Refering to the original Mini A Schematic, for Q6, my Drain voltage is +15.34v while my Source voltage is -14.65v. For Q7, my Drain voltage is -14.95v while my Source voltage is -15.03v.
Thanks!
Old 2nd September 2009, 01:01 AM   #5
vdi_nenna's Avatar
Compare FET voltages on the good board versus the bad one.
Old 2nd September 2009, 04:46 PM   #6
vdi_nenna's Avatar
happyboy,
From Grey's original article, "The Mini-A".
The idle voltages will all read about the same as the real Alephs:
--About 4 or 5 volts across R4
--9V across D1
--Roughly +4 volts at the sources of the front end differential, relative to ground
--About 4 or 5 volts across R3
--About 4 or 5 volts across Q4
I don't have my Mini-A at home or else I'd find out what the output sections should be doing. I think there should be at least a 4v drop across the MOSfets. You're seeing just about the full voltage. That's why I think the FETs are blown. I'm no expert though. Maybe someone else could help with this.
Also, check R18. The Source voltage seems odd.
Old 3rd September 2009, 08:42 AM   #7
happyboy,
Thanks for your help. Finally both Mini-A sings already. The reason for the failure was a damaged Q3. Swapped it and it worked. Thanks for your help vdi_nenna! Greatly appreciated.
Old 3rd September 2009, 12:51 PM   #8
vdi_nenna's Avatar
Don't know if I was any help, but glad you got it running!
What do you think of the sound?
V~
Old 9th September 2009, 02:37 PM   #9
V~
After using the Mini A for about a week, i can only say i love it~
mini-aleph versus aleph-3 rmgvs Pass Labs 7 4th February 2010 03:18 PM
Mini Aleph Board & Aleph 2 Parts List gpsmithii Pass Labs 3 16th January 2010 03:58 AM
Aleph Mini / Aleph 3 PCB ready (?) croccodillo Pass Labs 5 27th July 2009 01:51 PM
Difference between Aleph J and Aleph J Mini ppmmcc Pass Labs 5 17th May 2008 06:10 PM
WTB: Aleph-mini PCBs and transistor set for Aleph 30 needtubes Swap Meet 4 6th November 2005 06:29 PM
Page generated in 0.11283 seconds (73.66% PHP - 26.34% MySQL) with 10 queries
