F5 Help Needed
F5 Help Needed
Old 30th August 2009, 12:51 PM   #1
vdi_nenna is offline vdi_nenna  United States
vdi_nenna's Avatar
F5 Help Needed Send a message via Yahoo to vdi_nenna
Default F5 Help Needed
Hi All,
Still having issues with my F5 build. Replaced all active components and 4.7 ohm thermistors. Checked all resistor values; all are ok. Check for output shorts to case and none found. No input shorts either.
BTW- I checked the semies out of circuit and they all seemed to check out ok. (Must be a resistor value is incorrect?)
I can't seen to get the bias right on this second build. One channel goes up to about .314v across R12 and the other channel gets to about .51v until I run out of turns on the pots. Could R3 and 4 be the wrong values? I check them and they are correct as far as markings go. Used Bourns pots this time and they are very accurate. They do not have markings for ohm value.
Voltage across R3 & 4 are close to 4.2v as indicated in the schematic, but not perfect. I assume P1 and 2 influence this voltage? Also no DC at output.
Thanks for your input,
Vince
I build, therefore I am.
Old 30th August 2009, 03:45 PM   #2
tms0425 is offline tms0425  United States
Originally Posted by vdi_nenna View Post
Hi All,
Vince
I'm assuming you meant 4.7K not 4.7 ohm thermistors?
Old 30th August 2009, 04:23 PM   #3
vdi_nenna's Avatar
Yes, I went back to the order and checked. It is 4.7k Ohm.
Also something of note- when I would blow air over the circuit boards, the R12 voltage would rise several hundred millivolts, then drop back down to their current voltage. If I put my hand on the heat sink the voltage would drop slightly.
Old 30th August 2009, 08:58 PM   #4
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
F5 Help Needed
Cooling the Jfets and Fets with air seems normal in my book.
I only measure voltage across one of the source resistors, and leave the other DVM across the terminals and measure DC offset. As one pot goes up in turns, the DC offset should move and the source voltage. The idea being that if the source voltage is reasonable, and the DC offset reasonably low, your good. There should always be a value here.
Old 30th August 2009, 09:00 PM   #5
woodturner-fran is offline woodturner-fran  Ireland
2 things to do:
check your grounding and take some pics and post them here. That will help hugely.
Yes, if R11 and R12 are different values (eg one is .47 and other is 0.33) then you will get different voltages across them. If they got a good burn at any stage they may well have drifted.
What boards are you using?
Fran
Old 30th August 2009, 11:25 PM   #6
vdi_nenna's Avatar
I have no DC reading/movement at the outputs.
Using cviller boards. i have 2 coming from Peter Daniel soon.
I'll try to post pics but my camera is bad for close-ups.
Old 31st August 2009, 12:29 AM   #7
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
F5 Help Needed
I think it's either low Idss on the JFETs or high Vgs on the
Mosfets. I run into the latter often enough. Increase the
value of the resistor in parallel with the pot. I usually go from
1.2K to as high as 2.2K
Old 31st August 2009, 12:36 AM   #8
vdi_nenna's Avatar
Hi Nelson,
I used Jfets from the B1...I remember using Jfets for this amp with a low Idss...let me see...this time I used .29 and .18 on th 2sk170s. I did not measure the 2sj74 jfets.
You think this would explain the lack of DC at the outs?
Thanks!
Vince
Old 31st August 2009, 12:39 AM   #9
vdi_nenna's Avatar
Some pics...not good. BTW- I used IRFP9140 P-ch (100v 21a) and IRFP140 N-ch (100v 33a)
Used 2.2k for R3 and 4 from Fig 6. Should I go higher than 2.2k?
http://i145.photobucket.com/albums/r...s/DSCF0100.jpg
http://i145.photobucket.com/albums/r...s/DSCF0101.jpg
http://i145.photobucket.com/albums/r...s/DSCF0102.jpg
http://i145.photobucket.com/albums/r...s/DSCF0103.jpg
http://i145.photobucket.com/albums/r...s/DSCF0108.jpg
http://i145.photobucket.com/albums/r...s/DSCF0109.jpg
http://i145.photobucket.com/albums/r...s/DSCF0110.jpg
http://i145.photobucket.com/albums/r...s/DSCF0112.jpg
As you can see, I added board connectors this time for quick removal!!
Old 31st August 2009, 05:16 PM   #10
vdi_nenna's Avatar
Can I go up to 3.3k on the R3 & R4 resistors?
Thx.
F5 Help NeededHide this!Advertise here!
Help needed ! Inter M R300 schematics needed ! alexclaire Solid State 30 9th September 2009 06:14 AM
HELP needed cobology Car Audio 21 2nd March 2009 12:11 PM
Help needed please. sicknote Multi-Way 4 18th January 2008 08:27 AM
LT1964-adj Help Needed or Part Needed lgreen Parts 2 29th June 2007 02:50 PM
Copyright ©1999-2017 diyAudio
