F5 Help Needed
F5 Help Needed
Old 31st August 2009, 08:53 PM   #11
woodturner-fran is offline woodturner-fran  Ireland
Its hard to see cos the pics are a little out of focus, but it kind looks like you have the jfets reversed? Its probably just the blurry pic, but thought I'd say it anyway........ yes, you guessed it, guess what I did with my first attempt at building!!
Fran
Old 31st August 2009, 09:29 PM   #12
vdi_nenna is offline vdi_nenna  United States
vdi_nenna's Avatar
F5 Help Needed Send a message via Yahoo to vdi_nenna
Hi Fran,
The fet's flat faces are both pointing toward each other.
I build, therefore I am.
Old 31st August 2009, 09:34 PM   #13
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
F5 Help Needed
Originally Posted by vdi_nenna View Post
Can I go up to 3.3k on the R3 & R4 resistors?
Who will stop you?
When you measured those JFETs, what do you mean by
.29 and .18 ?
Old 31st August 2009, 09:41 PM   #14
OK, not familiar with the cviller boards (I built Peter Daniels ones) but I take it from your reply you have them the correct way around. Anyway, I'm only throwing out crumbs here. The master is speaking.......
Fran
Old 31st August 2009, 10:12 PM   #15
vdi_nenna's Avatar
.29 and .18 ?
The .29 and .18 values are from the Idss matching when I built the B1.
I have jfets with higher Idss values.
I'll throw in a few 3.3k and see what happens. Just wanted to be sure I wouldn't make things worse by changing the relationship between the 5k pot and R3 and 4. Then again...how bad can it get?
Thanks!
V~
Old 31st August 2009, 10:18 PM   #16
The one and only
F5 Help Needed
You should get values like 5 to 10 milli-amps. What
do you suppose .18 or .29 is?
Old 31st August 2009, 11:17 PM   #17
vdi_nenna's Avatar
Doh! I suppose I screwed up rather badly is what that is.
I was measuring DC instead of current.
Old 31st August 2009, 11:41 PM   #18
Well, that might mean that you haven;t matched them, but dosen't mean that they are not working! i had mine in backwards but no harm done to them.
The Q5 and Q6 - yours look really flat like ztx parts. but IIRC, cviller boards were made for BC550/560. If thats the case, maybe the pinout is different?
Just clutching at straws here.
Fran
Old 31st August 2009, 11:47 PM   #19
Yeah, see here:
http://www.diyaudio.com/forums/showp...&postcount=258
I remember it cos the ztx parts are hard enough to find in Europe.
Fran
Old 1st September 2009, 12:07 AM   #20
vdi_nenna's Avatar
Yes, I used the ZTX450 and 550. They were to go in backwards compared to the BC transistors.
My B1 sounds fine. By "fine" I mean sweet!
F5 Help NeededHide this!Advertise here!
Help needed ! Inter M R300 schematics needed ! alexclaire Solid State 30 9th September 2009 06:14 AM
HELP needed cobology Car Audio 21 2nd March 2009 12:11 PM
Help needed please. sicknote Multi-Way 4 18th January 2008 08:27 AM
LT1964-adj Help Needed or Part Needed lgreen Parts 2 29th June 2007 02:50 PM
Copyright ©1999-2017 diyAudio
